Reply 29100 of 30440, by zuldan
Figured out the right combination of EXE's to get software mode all the way to s3 virge mode for Tomb Raider and created a little menu.
The attachment Menu.JPG is no longer available
Made a super deluxe backplate for my ABIT NF7-S v2 using electrical tape technology.
The attachment Backplate.JPG is no longer available
Finding a proper backplate / IO shield is almost impossible....
Reply 29101 of 30440, by Veeb0rg
zuldan wrote on 2025-01-19, 01:45:
Figured out the right combination of EXE's to get software mode all the way to s3 virge mode for Tomb Raider and created a littl […]
I 3d printed one for a dual p3 motherboard I had. Took me a bit to get port alignment right but once I did it was a nice fit.
Reply 29102 of 30440, by oh2ftu
We had my kids 13th birthdayparty for his friends. A retro-lan 😀
10 stations ranging from p3-1GHz to a core i3-3220. Win98 or xp.
They played quake1-3, cs beta, midtown madness. What a blast.
I might have enjoyed setting these up as well. "Oops" 😀
Reply 29103 of 30440, by dr_st
Hey, I used this technology a while ago to cover a broken corner in my laptop chassis, where it hit the pavement. It's very versatile tech, it seems! 😁
Reply 29104 of 30440, by dominusprog
pan069 wrote on 2025-01-19, 00:47:
dominusprog wrote on 2025-01-18, 11:45:
Recapped this BEST UNION MF-719 sound card. Also replaced the transistor in the middle with a L7805CV regulator.
The attachment IMG_20250118_132458.jpg is no longer available
Looks nice and clean. I think I have this card in a box somewhere... 🤔
The build quality is not the best, but it's not the worst either.
Reply 29105 of 30440, by StriderTR
Got one of these old Compaq iPAQ (PD1085) systems, no idea what to do with it...
Has this motherboard in it "https://theretroweb.com/motherboards/s/compaq … 2-0-legacy-free"
All I know so far is it has a PIII and 512MB PC100 RAM in it. Also have a spare optical drive, as well as an LS120 SuperDisk Drive for it (LKM-FC33-8).
Never owned one, so not sure what it's capable of. From the little research I've done, it seems it's got some sort of hardware lock to use only Compaq hard drives?
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 29106 of 30440, by Ozzuneoj
StriderTR wrote on 2025-01-20, 00:36:
Got one of these old Compaq iPAQ (PD1085) systems, no idea what to do with it... […]
Wow, such a weird little thing. I think I remember seeing those 20+ years ago.
It could be fun to tinker with but that funky power supply and all the proprietary parts would probably stop me from getting too attached to it, for fear of it dying and being unfixable. Unless parts for them aren't hard to find for some reason.
Reply 29107 of 30440, by DaveDDS
Ozzuneoj wrote on 2025-01-20, 04:17:
There are ways to "work around" non-standard power supply failures 😀
Re: I recently found this hardware, AKA the Dumpster find thread.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 29108 of 30440, by Ozzuneoj
DaveDDS wrote on 2025-01-20, 13:34:
There are ways to "work around" non-standard power supply failures :-) […]
Of course, but that kind of kills the unique form factor of the machine in my opinion.
Anyway, if I had one I'd certainly tinker with it. I would be curious to know the limits of what games and software it would run acceptably with the Intel video and AC97 audio. If it supports a Tualatin PIII (TheRetroWeb says it should) it would make kind of a weird unbalanced retro gaming system. Not all that different from running a PIII with an i740.
Reply 29109 of 30440, by PD2JK
I'm trying to access a MiniScribe 8425 XT drive. When powering on without the 40pin cable, should it do some initialization? Or is that complete done by controller electronics on the main board? The head doesn't move at all. I rotated the axle/flywheel a bit, it is visible on the outside. Philips P3105 machine by the way.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 29110 of 30440, by ChrisK
Finally finished the VGA out cable for my Radeon 9600Pro AiW I'd begun here:
Re: What retro activity did you get up to today?
and here:
All that was necessary was to make a 3D-printed shell for the card end of the cable.
Took just roughly two years to complete...oh dear.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 29111 of 30440, by Kahenraz
Well done. I've always avoided these cards because of this adapter. It's hard to get a matched set when buying online.
Reply 29112 of 30440, by PcBytes
Got an VGA-HDMI adapter that finally works. Currently testing it out with a MSI 6168 mobo.
Reply 29113 of 30440, by Repo Man11
ChrisK wrote on 2025-01-23, 12:59:
Finally finished the VGA out cable for my Radeon 9600Pro AiW I'd begun here: Re: What retro activity did you get up to today? an […]
and here:
The Big Box 'O Video Cards at my nearest computer store has a very similar ATI video card, and I noticed that the adapter for it was in another nearby box of stuff. I decided I didn't need it, but I thought they ought to be together since each is useless without the other, so I screwed the adapter to the card and left it that way. The next time I stopped by, someone had again separated them for reasons that I do not understand.
Reply 29114 of 30440, by PD2JK
PcBytes wrote on 2025-01-24, 00:43:
Yeah HDMI enabled Voodoo3!
Still have to fix my board, it doesn't have SGRAM at the moment. 🫢
Reply 29115 of 30440, by dominusprog
After a week of work, finally finished recapping this AWE64-Value card. Working with these multi-layer boards is a nightmare 😓. Anyway, the purple 47uF caps in the center are Nippon, the two green 470uF on the right are Sanyo and the rest are made by Elna. Also installed a heatsink on the main chip 😁.
The attachment IMG_20250124_143143.jpg is no longer available
The attachment IMG_20250124_143217.jpg is no longer available
Reply 29116 of 30440, by PD2JK
That looks AWEsome! Do I spot Würth caps?
Examining a MiniScribe 8425XT drive. The LED gives me a diagnostic code.
The attachment 8425xt LED.png is no longer available
Something about the stepper for the heads. Doesn't move at all. I think the two stoere motor driver IC's need to be replaced. I found a few ST PBL3717A, so taking a gamble.
Reply 29117 of 30440, by dominusprog
PD2JK wrote on 2025-01-24, 16:53:
Thanks 🙂. If you mean the red cap on the bottom, that's the Elna Cerafine.
Reply 29118 of 30440, by RetroPCCupboard
I have spent about an hour today trying to find my CDs for The 7th Guest. No idea where they are.
Reply 29119 of 30440, by G-X
dominusprog wrote on 2025-01-24, 12:36:
After a week of work, finally finished recapping this AWE64-Value card. Working with these multi-layer boards is a nightmare 😓. Anyway, the purple 47uF caps in the center are Nippon, the two green 470uF on the right are Sanyo and the rest made by Elna. Also installed a heatsink on the main chip 😁.
Looks mint! What did you use to attach the heatsink? Thermal epoxy or tape?
Asking because for some reason while sorting through my cards i picked up a X-FI card and the heatsink was loose in the anti-static bag ... thing just fell off. No idea what Creative used but its very thin .. almost zero residue on the card or heatsink on the area of contact.
