Minimal hardware/peripherals to emulate for Windows
Reply 20 of 66, by GloriousCow
xsaveopt wrote on 2025-02-01, 14:08:
Yes, I can see from the emulator's side that it is resetting the mouse and then reading a few bytes including the 'M' identification byte.
But I must be seriously misunderstanding what mice were supported by the early Windows versions because I can't even get a serial mouse to work under Bochs. So I'm just going to trash it all and implement a PS/2 mouse instead, which hopefully will work better.
I guarantee you Win 2.0 supports a serial mouse. One of the first things I did when I got mouse working was play reversi.
MartyPC: A cycle-accurate IBM PC/XT emulator | web version: https://martypc.net | https://github.com/dbalsom/martypc
Reply 22 of 66, by xsaveopt
GloriousCow wrote on 2025-02-01, 14:06:
You can see if you go to martypc.net that the ctmouse driver loads and detects a mouse. You could try that.
Indeed, it seems that cutemouse does work.
I have now implemented a Logitech BusMouse (because PS/2 re-uses PPI ports and I didn't want to risk breaking GLaBIOS somehow), and it works under DOS. In Windows 3.0 however, I cannot see the mouse on the screen but clicking does open things.
Is the cursor by any chance drawn using a dedicated CGA or CRT register that I should have implemented?
Reply 23 of 66, by GloriousCow
xsaveopt wrote on 2025-02-01, 15:51:
Nope, CGA doesn't know anything about mouse cursors. That's peculiar. You tried PC Paintbrush yet?
Reply 24 of 66, by xsaveopt
GloriousCow wrote on 2025-02-01, 17:13:
PC paintbrush seems to expect a functioning x87 coprocessor, which I unfortunately have not implemented yet.
I can run Windows' paintbrush, but it's quite hard to use since the cursor is not visible:
The attachment win3_paintbrush.png is no longer available
Reply 25 of 66, by GloriousCow
xsaveopt wrote on 2025-02-01, 17:45:
what gives you that impression? I certainly don't have an x87...
Reply 26 of 66, by xsaveopt
GloriousCow wrote on 2025-02-01, 19:16:
When I try to run PBSETUP (from PC Paintbrush 3.77) it tries to execute the FCOM instruction, which I haven't implemented yet.
Reply 27 of 66, by Jo22
GloriousCow wrote on 2025-02-01, 14:11:
I second this.
In addition, I read on the internet that the Windows 2.x PS/2 mouse driver had been used to retrofit Windows 1.x with PS/2 support..
I've attached some pictures of my own copy of Windows 2.03, hope that's okay.
The mouse (Sigma mouse) is a serial mouse that's MS Mouse compatible, though it also has a switch on underside.
It works so far with Windows, GEM, GeoWorks Ensemble and MS Mouse driver 6.24.
I do have to happen that setup around right now because I'm tinkering with a Commodore PC10 (4,77 MHz XT) right now and I just had my own issues with Windows 2.03 a few days ago.
I even went so far and asked for help at Forum64, a forum of Commodore experts.
The issue back then wasn't mouse related, though.
It rather was about an Aztech SB 2 clone that caused Windows 2.x to hang. Very strange.
A real SB 2.0 CT1350B didn't cause the issue. In another PC, a Siemens-Nixdorf model M35 (4,77 MHz XT), the Aztech SB 2 clone didn't hang Windows 2.x at all.
I even copied both Windows 2.x Installations back and forth, but the issue remained. Both have a NEC V20 processor, as well.
So yeah, I suppose Windows 2.x has quite some more surprises left for us. 😀
Reply 28 of 66, by Jo22
xsaveopt wrote on 2025-02-01, 19:50:
Oh, I can explain! Windows 2x uses WIN87EM.EXE if an application uses FPU.
It should be in Windows directory or application directory. It's not part of Windows installation, though.
WIN87EM.EXE is like win87em.dll in modern Windows.
It manages context-switching for FPU/applications and can both emulate/virtualize an 8087 FPU (AFAIK).
Edit: I've attached a copy of WIN87EM.EXE, along with a mandelbrot set generator.
Edit: I forgot to mention. WIN87EM can also be loaded at run time by adding it to WIN.INI (load=win87em.exe).
The downside is that it may consume a bit of conventional memory that could be used otherwise.
Reply 29 of 66, by Jo22
Hi. Here's also my old copy of MS Mouse 6.24BZ that I've used for ages. It's from 1988 or 1989.
So far, it worked with about any mouse/application I've tried.
Windows doesn't use it, but it won't take any harm from it either.
Reply 30 of 66, by GloriousCow
Jo22 wrote on 2025-02-01, 19:59:
lots of things can probe the FPU. FDISK in DOS 3.30 does for some reason. If you don't have one installed all that happens is an ESC opcode gets execute and the CPU continues, unless WAIT gets executed. The fact that you even know FCOM was in there somewhere makes me think that you're triggering a halt on ESC? If so, try taking that out. Just do a dummy fetch of an EA operand and keep going.
Reply 31 of 66, by xsaveopt
GloriousCow wrote on 2025-02-01, 21:00:
I can't even decode the instruction yet, and for now I'm just aborting emulation when I encounter an unknown instruction. But even if I add only the specific instructions it encounters it still doesn't work for some reason.
I also tried running DeluxePaint 2 and it worked perfectly, including mouse:
The attachment deluxepaint.png is no longer available
So it seems like it really is only Windows where the mouse cursor isn't drawn for some reason.
Reply 32 of 66, by superfury
Perhaps a video card MMU issue? Usually things like mouse rendering uses XOR write modes etc. from what I remember.
At least on the EGA/VGA.
Or perhaps an issue with algorithmic x86 instructions (resulting flags and/or results) otherwise?
Edit: While googling it, I also found:
https://learn.microsoft.com/en-us/previ ... dfrom=MSDN
Once again, perhaps XOR-related (a flag that affects rendering the mouse cursor being flipped).
UniPCemu Git repository
Reply 33 of 66, by xsaveopt
superfury wrote on 2025-02-02, 11:16:
Perhaps a video card MMU issue? Usually things like mouse rendering uses XOR write modes etc. from what I remember. At least on […]
I'm just doing CGA for now, so presumably Windows is just software-rendering the cursor itself. I've tested my implementation against GloriousCow's single-step tests, so all flags (except for the undefined flags) should behave correctly.
Reply 34 of 66, by superfury
xsaveopt wrote on 2025-02-02, 15:21:
Afaik if it's software-rendering the mouse cursor (the same with MS-DOS text screens in graphics mode) it renders it using some kind of XOR operation (like VGA's XOR). That way it blits it onto the screen.
Also, apparently, it can be disabled for screen captures (clearly noticed on Windows 2000 or XP I linked to). It might be that that flag is never set (or cleared) properly.
The CGA doesn't have anything like XOR blitting like EGA/VGA has, or does it? I can't remember.
Reply 35 of 66, by Jo22
Hi. Did a bit of experimentation. The mouse works in PC-Ditto from 1988.
PC-Ditto emulates a basic PC/XT compatible and a Microsoft serial mouse.
I've used PC-DOS 3.30 and a minimal installation of Windows 2.03, which works in DOSBox (machine=CGA).
Windows setup program was told to use CGA, Microsoft Bus/Serial mouse.
The graphics are glitchy, the Windows splash screen animation is broken and the MS-DOS Executive never shows up.
However, the mouse pointer is being drawn and it reacts to the mouse movement. I can do make circles, go up/down etc.
The files used are:
coura.fon, msdos.exe, uhr.exe, win200.bin, win200.ovl, win.com, win.ini
command.com, ibmdos.com, ibmbio.com
The Atari ST emulator used was Steem v3.2.
Emulated Atari ST had 4 MB of RAM, Color Display, TOS 1.04 / TOS2.06 (tried both)
Reply 36 of 66, by Jo22
And here's the same minimal installation in DOSBox (machine=CGA).
Reply 37 of 66, by superfury
It truly sounds like there's an error in your CPU emulation then. Try looking into algorithmic instructions and otherwise perhaps (conditional) jump instructions.
Reply 38 of 66, by xsaveopt
superfury wrote on 2025-02-04, 09:24:
I'm verifying virtually all execution against the behavior of a real CPU. There are only a handful of instructions I can't verify (in/out, sti/cli, pushf/popf, iret, shifts, etc.). So an error in the CPU emulation seems unlikely.
Jo22 wrote on 2025-02-03, 00:54:
Thanks for checking this! I'll try to see if I can compare I/O port reads and writes when I have some time.
Reply 39 of 66, by Jo22
PM sent.
