First post, by JustRob
There’s probably an easy solution but I’ve been up half the night dealing with shitty broken floppies and drives not working the way I want, so I could use some help.
Got a PC with Windows ME on it. It’s a PC that’s stupid to have Windows ME on, also Windows ME itself is stupid. I want Windows 95 on it.
So the first thing I tried to do is hook up another PC that already has Windows 95 on it to make a boot disk, using the Control Panel > Software thing. Didn’t work, kept getting errors. Tried at least 10 different floppies, all the same shit. Tried a different floppy drive, same shit.
Then I tried the same thing, but now on Windows 98 SE. Same stuff, just errors no matter how many floppies I tried.
Then I figured, maybe I’ll try installing Windows 98 SE instead, and then do 95 later. So tried booting from the Windows 98 install CD, didn’t work. Some kind of error that device can’t be booted.
I finally went back to the installation already on the PC with Windows ME on it, and to my great surprise I was finally able to make a boot disk using Control Panel > Software in Windows ME. So I booted from the boot disk, ran fdisk, formatted the C: drive, smashed in my Windows 95 install CD and ran setup.exe from the CD-rom drive. Error. CDR101 not ready. Abort, Retry, Fail?
Okay. It doesn’t run from the CD for some reason. That’s fine, I like copying stuff over and running it from the hard disk anyway. So I make a directory on C:, go to E:\win95, and run *.* to copy everything over. For every file, error. CDR101 not ready. Abort, Retry, Fail?
And before you say bad disc drive, I actually have two disc drives in this PC, and they both give the same error. They also read disks just fine in the OS when Windows ME was still on here.
So then I decided to give up and go ask for help here. After I wake up I’ll try some other disc drives anyway. In the meantime, if anyone has any ideas, I’d love to hear them.
Reply 1 of 11, by jakethompson1
You shouldn't have to do this, but the only thing I can think of is to try a different ATAPI cdrom driver than oakcdrom. Such as xcdrom from FreeDOS
Reply 2 of 11, by wbahnassi
Is it an original media print or a burned CD-R/W? The latter might not read on older drives... but then you say it read fine from within Windows Me on the same machine? ... Hmmm... but I've never seen OAKCDROM fail this way on an IDE ATAPI drive...
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 3 of 11, by JustRob
Burned.
Tried 3 disc drives now. What are you supposed to do when you can’t run the setup or copy from the CD? I guess I need to get actual Windows 95 install floppies ¯\_(ツ)_/¯
Reply 4 of 11, by Ydee
What you see, if you use: E:\dir ?
Reply 5 of 11, by DudeFace
JustRob wrote on 2025-02-02, 14:09:
Burned.
try burning at a lower speed if you havent already make sure your not doing anything else on the computer at the same time (close all browsers/programs) if the buffer runs low you may get write errors, also could be the drive your burning with thats the issue, select the lowest speed your drive can do in imgburn dont burn at maximum as old drives wont like it, you may have some luck, also try a boot iso instead of floppy make sure its one that includes ramdrive, if that doenst work try installing with a different computer, for a couple of my old laptops i put the hdd in another computer to install win98 also i copy all drivers needed to a folder then swap the hdd back and let it detect all devices then install my drivers.
Reply 6 of 11, by JustRob
I’ll try installing Windows 95 on the HDD in my main rig and then swap it over. Hopefully that works.
Why can’t stuff ever just work
Reply 7 of 11, by Harry Potter
JustRob, I feel your pain. I've been having a lot of issues with a Win98SE tower at my mother's house, including Windows not booting properly if I use any EMS manager other than UMBPCI. The latest issue is it crashing while installing the necessary drivers while installing Windows. I really want Win98SE, as there are some things I want to do on it. And I like the GUI's color selections: Since then, Windows was losing on that aspect of the GUI: even WinXP, even though it had a more elaborate GUI, only had three color choices for certain window colors. 🙁
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 8 of 11, by JustRob
Yeah it’s rough.
Swapped my HDD over to my main PC, same error. At this point, it’s the disc. I have no idea how I used this disc to install Windows 95 in the past (I’m sure I have at least once), but it doesn’t work now.
Guess I’ll try burning a new one at the slowest speed possible
Reply 9 of 11, by JustRob
Well, it finally worked using a new CD. Crazy that I could read the old disk but not copy or run anything from it. Oh well
Reply 10 of 11, by chinny22
All been there, does make emulation almost appealing sometimes!
What I like doing is having a 2nd drive or partition with the Win95 folder on it (You don't need the whole CD just the WIn95 or Win98 folder to install windows) plus at least the most important drivers.
That way if you ever need to wipe c:\ for a clean install or whatever, the needed files are nice and safe on something more reliable than floppy/CD.
If you have networking setup (FTP, SMB, whatever) you can then copy the rest over the network and hardly need the CD drive.
Reply 11 of 11, by DudeFace
glad you got it sorted in the end, what i usually do is after install before installing drivers, i copy all files from the hdd to a folder for backup making sure to copy hidden files/folders, then if anything messes up i just delete everything then copy all files back across, saves having to sit through another install, if im setting up a new computer ill setup the drive with FDISK then just use my backup files, not had any problems doing that so far.
