Reply 55940 of 59896, by dominusprog
- Oldbie
Ozzuneoj wrote on 2025-02-02, 10:10:Just be very careful with it and make sure that anyone that may interact with the machine knows that it does NOT lock unless a d […]
dominusprog wrote on 2025-02-01, 21:32:Major Jackyl wrote on 2025-02-01, 19:49:Got some good stuff today. […]
The fact that you can't rotate the lever without any floppy inserted is very cool.
Just be very careful with it and make sure that anyone that may interact with the machine knows that it does NOT lock unless a disk is inserted.
I had a similar drive and the plastic sleeve+bump that acts as the locking mechanism is just press-fitted onto a steel shaft with a notch cut in it. So, the twisting force applied to the lever on the outside translates to a twisting force (with leverage) of 30+ year old plastic on a steel rod. The white plastic may be different, but on the black ones this causes the plastic to crack in multiple places, which prevents the lever from working at all. 🙁
The way I fixed it was actually to wrap the cracked plastic sleeve several times in wire-wrapping wire (with the shielding stripped off), and then using a soldering iron to melt the wire into the plastic to give it some strength. Last I knew it was still operating... but this was not a fun process!
There are other drives that have the same mechanic. I hope somebody make a 3D model for these parts.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
