First post, by DustyShinigami
Could someone recommend a decent and affordable SVGA compatible GPU? I presume my Riva TNT theoretically supports it, but according to one game’s uvconfig utility, it can’t detect any SVGA graphics card. I’ve tried forcing it and I’ve tried UniVBE tools, but it still doesn’t work properly for me. Or the game has just refused to boot altogether.
Also, does anyone have, or know where I can find, a list of all supported SuperVGA families/chipsets? I keep trying to access the list with the command for uvconfig.exe, but everything goes by way too fast. And the /p switch doesn’t do anything. I’ve tried checking on Google as well.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 13, by wbahnassi
SVGA is any VGA card that supports modes beyond standard VGA. There are tons of those. Under DOS, VESA extensions help games utilizes SVGA modes, and under Windows the display driver takes care of everything.
But I'm surprised the Riva TNT isn't supported by Univbe. Maybe use a newer Univbe version?
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 2 of 13, by DustyShinigami
wbahnassi wrote on 2025-02-04, 21:26:
Okay, thanks for clarifying. I just figured if I went for an earlier model, like the ones listed/supported, there'd be less of a problem. In theory.
It doesn't look like I have any other games that are SVGA that make use of UniVBE. Some are SVGA, but I'm guessing they're configured differently. For this particular title, it has the UniVBE driver and configuration file present on the disc, but yeah... It doesn't recognise my card. I did try different versions of UniVBE, including 5.3 and 6.-something. One still doesn't support the card, whereas the other (5.3, I think) has to have a patch installed so it supports it. But even then, I swear it's made things worse. I'll have to try again and see, but I couldn't get it to work properly.
OS: Windows 98 SE
Reply 4 of 13, by DustyShinigami
megatron-uk wrote on 2025-02-04, 22:12:
I'm surprised that the TNT doesn't already have a VESA compatible bios.
Anyway, have a look here for some mods to get Univbe working with the TNT and later Nvidia cards:
NVPatch - making UniVBE work on NVidia cards
Yeah, that's the patch I used, which I mentioned above. I also want to stay clear from SciTech Display Doctor. I tried that twice and it made my PC act weird. To the point it wouldn't boot. I'll certainly try playing around with it all again. One thing I did notice in that link you provided, was that the final poster mentioned it worked as expected with the Geforce 4 MX440, which I have as well. Though that was a PCI variant.
OS: Windows 98 SE
Reply 5 of 13, by Gmlb256
Only UniVBE 6.7 has official support for the RIVA TNT, gains from it are 15bpp and some low resolution VESA video modes. However, 6.7 is the worst version overall as the quality of the utility decreased.
nVidia cards starting from RIVA 128 comes with a good VBE 3.0 implementation but it isn't perfect in terms of compatibility. The OP was having problems with Broken Sword and other DOS games relying on SDD/UniVBE drivers.
Reply 7 of 13, by DustyShinigami
chinny22 wrote on 2025-02-04, 23:49:
Time for one of the most linked tables on vogons!
https://gona.mactar.hu/DOS_TESTS/
Ooh. Perfect. Thanks for this. That looks very detailed and in-depth.
OS: Windows 98 SE
Reply 8 of 13, by DustyShinigami
DustyShinigami wrote on 2025-02-04, 22:41:
Yeah, I've just checked and 6.7 was the first one I tried and it wasn't recommended. And I remember that I did test it with the Geforce 4. I just can't quite recall what version I tried, but I do remember it working with it. But it looks like 6.53 and 6.7 are the only ones that work with the Riva TNT.
OS: Windows 98 SE
Reply 9 of 13, by DustyShinigami
Yeah, I’ve re-tested it with 6.53, along with the patch. Even though it’s all set up and working, the game’s uvconfig.exe file still complains there’s no SuperVGA chip detected.
I mean, the game does work, but I’m just curious about other period accurate SVGA cards that are supported in case I buy any future games that don’t like/work with either GPU I have. So I have something to fall back onto for a specific game. 😀
But I’ll check through that list when I have a moment.
OS: Windows 98 SE
Reply 10 of 13, by leileilol
Many forget that the Scitech Display Doctor and UniVBE halted development when competent contemporary 3d-capable video cards generally arrived in early-mid 98 (the dos gaming expiration period), so a lot of that advice tends to be misguided (and some games that try to conveniently integrate univbe to run end up making more compatibility issues). SDD really shines for the earlier chips with non-VESA/exotic SVGA, Tseng cards and S3 Trio cards.
Reply 11 of 13, by konc
DustyShinigami wrote on 2025-02-04, 20:48:
You mean the -f option? If so you can redirect the output to a text file and read it afterwards
uvconfig.exe -f >out.txt
Reply 12 of 13, by DustyShinigami
konc wrote on 2025-02-05, 07:42:
That’s the one, yeah. Ahhh. Thank you so much! I’ll have to add that to my ever growing list of DOS commands learnt. 😁
OS: Windows 98 SE
Reply 13 of 13, by DustyShinigami
leileilol wrote on 2025-02-05, 03:03:
I see. The only game it has helped so far is Discworld 2 with version 53, I think. So hopefully I won’t need to rely on it any further.
OS: Windows 98 SE
