JustRob wrote on 2025-02-05, 13:44:
Win32 Disk Imager says its intended use is for removable media, aka USB drives and flash cards.
Obviously. I didn't expect it to say it's also meant for vintage HDDs attached to an USB-PATA converter. That's.. very niche and not very 2025, after all. 🙁
HDDs as such are an anachronism these days.
What Win32 Disk Imager does is similar to what "dd" does on Linux. It reads/writes raw sectors.
I've also got an SATA copier device that does same. You have source/destination device and a copy button.
And at least on Windows, an USB HDD should appear to be a removable medium like any other.
If the HDD controller accepts any weird drive geometry, is another question of course.
Also depends on the USB-HDD bridge chip of the HDD enclosure/USB converter, I do assume, some do use an translation.
That way I got an 8TB USB HDD to work on Windows XP, for example.
It works with just that one external HDD here, because the older enclosure does additional translation.
Anyway, here's an utilities that does explicitly mention HDD support.
.. And It's being inspired by Win32 Disk Imager (sorry, couldn't resist!) 🙂
"A handy Windows tool for writing a disk images to the physical devices (HDD, SSD, USB sticks or SD/CF cards)."
https://github.com/raspopov/VisualDiskImager
