First post, by Vendein_RaZoR
No doubt, the last most reliable motherboards on reliable chipsets was released in 2007-2008 years. "Reliable" means chipset's packages was based on wirebond technology, because flip-chip package technology may cause failure over time because of temperature, lead-free problems e.t.c. Thus, these chipsets never suffer from unexpectable behaviour while proper explotation (not working USB, memory slot problems, black screen e.t.c.). The last chipsets that satisfy these conditions was SiS and VIA and based on PCI-Express and AGP interfaces. I think, these chipsets outlive all modern chipsets! (but maybe not AM4 😀)) I bought and explored a lot of motherboards on SiS and VIA to found out some features and all boards were working !!! 😀
So, this research was useful to find out which motherboard the best or choose proper motherboard for your own purposes (I know some people used these boards for Windows 98 machines). So, lets start.
----------------------------------------------ALL BOARDS FEATURES---------------------------------------------
- All boards have single-channel memory with a maximum working volume of 2.5-3.5 GB average (usually about 3 GB), it is impossible to achieve a larger volume, even if the BIOS shows 4 or more GB, this is a limitation of the chipset and if you install more, then, for example, blue screens, freezes and reboots may be observed in Windows, therefore, as a rule, 2-3 GB of memory were installed on such boards. This happens because those chipsets was designed for PCI bus. So simple PCI is 32-bit bus, hence addresses of this bus located below 4 Gb address space and those chipsets haven't any methods like MTRR or others (like AMD) to remap PCI address above 4 Gb. Also, integrated video needs some space in memory, that makes free memory smaller too.
- Also, no one of these boards supports 1333 MHz (QPB) bus (333 MHz is the original frequency), so even if processors with 1333 MHz work, then either unpredictable behavior (crashes, reboots, blue screens, etc.) may be observed, or the processor will not work at full performance (for example, unbalanced load on cores), or the board itself will set the minimum frequency multiplier, which will again lead to the processor not working at full performance, and somewhere you will even have to change the bus frequency in the BIOS to a lower settings for it to work. The maximum for these boards is 1066 MHz QPB bus (266 MHz original source).
- The best integrated video is in the latest VIA P4M900 chipsets (Chrome 9 HC), everything older does not support DirectX 9.0, but only 6.0 (VIA UniChrome) with all the consequences (the inability to run games, or the graphics are very poor). P4M900 has at least 1 vertex shader unit, which is very suitable for 3D. Earlier versions and even SiS chipsets (all of them), which are not necessarily equipped with T&L units, do not have a vertex shader unit, only pixel ones, so you shouldn't count on 3D, only 2D, watching videos, etc.
----------------------------------------------VIA BOARDS FEATURES---------------------------------------------
- Boards on the VIA chipset have a specific PCI-Express 1.0a bus, which does not work with video cards and other PCI-Express 3.0 devices, and everything with a version lower - as luck would have it. GeForce 710 and 730 should work, but not all, for example, AFox video cards work, and ASUS do not work. All new controllers like PCI-Express-SATA, USB 3.0 and others do not work, you need to look for old versions of controllers, like SATA JMicron, etc. So, my advi ce is not ot look on VIA PCI-Express chipsets for graphics and other and use AGP socket 775 chipsets with simple PCI, because otherwise it will be a lottery with PCI-Express cards.
- The VIA VT8237S south bridge, although it has SATA-II (300 Mb/s), works on 1 channel (usually on the boot channel, from which the OS starts, but if the IDE channel is used, then sometimes all SATA channels can be reset to SATA-I), the second channel is SATA-I (150 Mb/s). This is how it differs from the VT8251, it supports 3 Gb/s on all channels (that's why manufactures sometimes put a radiator on it), and the 8237S is its cut-down version.
- The VIA P4M890 chipset does not support 4-core processors, do not even try, if you succeed, the operation will be unstable, if at all possible.
- DDR2 533 MHz with big latencies - the same like DDR1 400 MHz
----------------------------------------------SIS BOARDS FEATURES---------------------------------------------
- The SIS 968 south bridge operates in SATA-II mode (300 Mb/s) only with hard drives (with SSD it drops to SATA-I, 150 Mb/s), such an interesting feature, but there is an AHCI support.
- Also, despite the presence of a gigabit Ethernet controller in the SIS 968, 100 Mb PHY are often installed on the board, so the speed is ultimately limited to 100 Mb
- SiS chipsets are the best with PCI-Express unlike VIA, all cards that i tested on almost all boards are worked properly
Legend/Notes:
(1) This board only support Core 2 Duo 65 nm
(2) This board only support Core 2 Quad and 65 nm
(3) This board support Core 2 Quad and 45 nm
----------------------------------------------PCI-EXPRESS BOARDS---------------------------------------------
(1) ASUS P5V-VM ULTRA ----------------------------- VIA P4M890 + VT8237A, 533 МГц DDR2
(1) ASUS P5VD2-MX SE ----------------------------- VIA P4M890 + VT8237A, 533 МГц DDR2
(1) ACER (FOXCONN) 672M01 ----------------------------- SiS 672 + 968, 667 МГц DDR2
(1) ASUS P5VD2-MX ----------------------------- VIA P4M890 + VT8237A, 533 МГц DDR2
(2?) ASUS P5VD2-VM SE ----------------------------- VIA P4M900 + VT8237S, 667 МГц DDR2, no microcodes for Core 2 Quad
(1) ASUS P5VD2-X ----------------------------- VIA P4T890 + VT8237A, 533 МГц DDR2
(1) ECS P4M890T-M ----------------------------- VIA P4M890 + VT8237A, 533 МГц DDR2
(2) FOXCONN P4M9007MB-8KRS2H ----------------------------- VIA P4M900 + VT8237A, 667 МГц DDR2, Gigabit Ethernet, the most convenient location of PCI-Express x1 and overclocking feature
(2) ASUS P5V-VM SE DH ----------------------------- VIA P4M900 + VT8237A, 667 МГц DDR2, internal Wi-Fi module, Gigabit Ethernet and overclocking feature
(2) ASUS P5VD2-VM ----------------------------- VIA P4M900 - VT8237A, 667 МГц DDR2, the same as P5V-VM SE DH but without Wi-Fi
(2) ECS P4M900T-M (REV:1.0) ----------------------------- P4M900 + VT8237A, 667 МГц DDR2, overclocking feature
(2) ASUS P5S-MX SE ----------------------------- SiS 671FX + 968, 667 МГц, Gigabit Ethernet
(3) PCChips P33G (671T-M3) ----------------------------- SIS 671 + 968, 667 МГц DDR2, overclocking feature, memory overclocking up to 800 MHz (but practically 750 MHz), the BEST VRM for QX6700 !!!
(3) ECS 671T-M ----------------------------- SIS 671 + 968, 667 МГц DDR2, overclocking feature, memory overclocking up to 800 MHz (but practically 750 MHz), weak VRM for Core 2 Extreme, but it works 😀
(3) ECS P4M900T-M2 ----------------------------- VIA P4M900 + VT8237S, 667 МГц DDR2
(3) GIGABYTE GA-VM900M ----------------------------- VIA P4M900 + VT8237S,667 МГц DDR2
(3) FOXCONN 671MX ----------------------------- SiS 671 + 968, 667 (800 тестовый) МГц DDR2, overclocking feature, the only board on SiS, that works with PCI-Express cards selectively (for example, Palit GTX 650 works, but Asus GT 730 -not)
(3) ASUS P5SD2-VM ----------------------------- SiS 672 + 968, 667 МГц DDR2, very strange board with strange BIOS without limits, like CPU multiplier or maximum RAM size (I tried to set 4+4 Gb DDR2 modules and it recognize it, but further not working properly, it cause blue screen and other on boot stage
----------------------------------------------AGP BOARDS---------------------------------------------
About AGP boards you can read here LGA 775 Motherboards with AGP Slots
(1?) P5VDC-MX V2.0 ----------------------------- VIA P4M800PRO + VT8251, it works with Core2 Quad, but unbalanced load on cores (maybe i find out it better)
(1?) ECS P4M800PRO-M2 ----------------------------- VIA P4M800PRO + VT8237R+, it works with Core2 Quad, but unbalanced load on cores (maybe i find out it better)
This post may be supplemented
