First post, by megatron-uk
I have a number of old laptops that I am restoring, some may make it, some won't! But all have a common issue of excess heat and fan noise.
I suspect most of this is down to the thermal interface material degrading. In fact some of the models I have taken apart show the thermal pad has gone hard and brittle, so I expect has not been transferring heat effectively... Or at all!
These pads vary in thickness depending on whether they are on mmc-1 or mmc-2 modules or on soldered on parts. Most are PII or PIII / Celeron processors.
Is there anywhere I can get an assortment of thickness pads to replace these? Most are beyond the ability of thermal paste to take up the space between die and heatsink.
https://www.target-earth.net
Reply 1 of 5, by megatron-uk
Heres an example:
The attachment IMG20250208102328.jpg is no longer available
Crusty!
Reply 2 of 5, by swaaye
Electronics suppliers like mouser and digikey sell them.
That crusty thing might be phase change material and still fine.
Reply 3 of 5, by smtkr
These are very common and are sold all over the place. I think I bought most of mine on Amazon (I think gelid was the brand that I ended up buying in various thicknesses).
Reply 4 of 5, by megatron-uk
I had a bit of a search today and found some that were available in a reasonable time frame.
The thinnest I could find without spending more money than the laptops themselves were 0.5mm. I suspect that's fine for most of the pads I've seen, though possibly needing to double up on the mmc-2 modules which seem to use a thicker pad.
Reply 5 of 5, by MikeSG
If you want to "set it and forget". Try thermal phase-changing material. Such as Honeywell ptm-7950.
Resists pump out and dry up.
You can't use thermal pads on the CPUs on laptops. Needs to be a thermal paste or phase-change material. Pads only transfer 1-5 degrees per second. Thermal paste/PCM transfers 10-50 degrees per second.
