Reply 540 of 548, by TheMechanist
- Newbie
... I'm using an interrupt 'cause it's a player routine for background sound ... at least it even works when DOSBox is set to 50 cycles fixed 😀 which is a computer about 0.28 MHz (Landmark says) 😀) ...
btw. seems, that there are some interesting VGM Tools:
Conversion (looks promising, tried a AY8910 VGM to YM3812 Conversion, not perfect but works!)
https://github.com/digital-sound-antiques/vgm-conv
VGM Packer (for 8 bit systems) which is interesting, 'cause it reduces the VGM "sample rate" from 44100 Hz to 60 Hz (chip tunes delays I guess) .. must try it for YM3812
https://github.com/simondotm/vgm-packer
Nec Powermate 80286, 12 Mhz, 1 MB RAM, onboard Paradise VGA, 130 MB ST3144AT, ES1868 ISA soundcard, MS Dos 3.31
Unchained demo group
swap42
