DB15 to MIDI
First post, by NadJ
Think I've bitten more than I can chew.
I have a SoundBlaster AWE64 with a DB15 style game port. The MIDI adapter cable for these are impossible to buy in the UK, so I decided to make one by buying a DB15 modular breakout connector and a standard MIDI cable. I've spliced the MIDI cable hoping to join the 5 wires (plus ground) to the DB15 connector. I did this after coming across a pin out diagram:
http://www.suntekpc.com/htm-2/cb-midi-5mm-15f … le-and-male.htm
But looking at this more carefully, looks like they might be using various resistors and possibly even capacitors! (electronics isn't my forte).
Has anyone done this before?
Thanks
Reply 1 of 7, by NadJ
Photos
Reply 2 of 7, by keenmaster486
TexElec makes the best version of this adapter, and does ship to the UK, in case you wanted to just buy something.
Otherwise, try this page: https://mitxela.com/other/midi_spec
World's foremost 486 enjoyer.
Reply 3 of 7, by Jo22
Hi. MIDI uses a current-loop interface, an opto-coupler is being recommended.
The resistor solution is what makes those cheaper models of USB-MIDI cables so unreliable.
The 5v for MIDI port should come from its own pins, rather than from the other computer's MIDI port - hence the opto-coupler.
Reply 4 of 7, by weedeewee
NadJ wrote on 2025-02-12, 17:38:
Think I've bitten more than I can chew. […]
Thanks
Yeah do not use that schematic.
the site keenmaster486 posted has a proper schematic, though since you lack any electronics knowledge and I guess soldering skill I will also side with the buy yourself one option.
This https://www.serdashop.com/DB15MIDI has two midi out ports. it lacks midi in, though I don't know if he'll ship to the uk even though it's not that far from the uk. 😀
This https://texelec.com/product/sb-midi-joystick-adapter/ expands to midi in, out and a two joystick ports.
edit: the schematic on the mitxela site is labeled Figure 2: Joystick/MIDI Adapter Diagram
Do not ask Why !
Reply 5 of 7, by Jo22
I second that, the schematic by keenmaster486 is the proper one.
It might look a bit complicated at first, but it isn't on a closer look.
Reply 6 of 7, by NadJ
TaxElec seem to market their's as SB compatible
Seems the safer bet. 60 dollars with shipping. I've done worse.
Cheers guys
Reply 7 of 7, by zwrr
The author of HardMPU-wt has a MIDI cable project that you can easily make one based on.
https://github.com/PickledDog/sb-midi
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
