First post, by SVslw
Hello everyone. I got my hands on a Asrock 980De3/U3s3 motherboard, which has floppy controller implemented through Nuvoton NCT6776D Super I/O chip. I connected a USB floppy drive and an internal 5.25 floppy drive, enabled fdc in bios and set it up as 1.2mb/5.25. But I don't see it in File Explorer neither in Device Manager. Any help is appreciated! 🙁
Once again: I turned on a floppy controller in bios, that's definitely not the case.
Reply 1 of 16, by SVslw
Sorry if this question is too lame xD
Reply 2 of 16, by SVslw
Accessing A: drive from FreeDOS USB just hangs.
Reply 3 of 16, by SVslw
bios
Reply 4 of 16, by DaveDDS
SVslw wrote on 2025-02-13, 21:15:
Does "onboard floppy controller" mean that you have an actual FDC chip on the mainboard (with
connections for non-USB floppy drives?
If may be that you have to either:
-Use a non-USB floppy drive connected to the mainboard, enable the on-board FDC in BIOS, and NOT use the USB one.
or
-Disable the on-board FDC in BIOS and use the USB one.
Just a thought... I've got a SFF Dell system which an 0nboard FDC but no corresponding drive.
I have onboard-FDC disabled in BIOS and it does find/boot/work with a USB floppy!
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 5 of 16, by jakethompson1
I have that board also. Are you sure you are using the correct ribbon cable? The A: drive needs to be after the twist. And the twist needs to be in the right place--there is another 34-pin cable with a twist for MFM/RLL hard drives that will physically fit but is not correct, here.
Reply 6 of 16, by SVslw
jakethompson1 wrote on 2025-02-13, 22:27:
Yeah I'm using the correct one. Shouldn't floppy controller work even if the floppy drive is missing?
Reply 7 of 16, by SVslw
DaveDDS wrote on 2025-02-13, 21:59:
Does "onboard floppy controller" mean that you have an actual FDC chip on the mainboard (with connections for non-USB floppy dri […]
or
Thanks for a reply, gonna try booting FreeDOS without USB drive. But in the case of Win10, it didn't see internal floppy drive even without USB FDD
Reply 8 of 16, by Major Jackyl
SVslw wrote on 2025-02-13, 22:50:
Indeed it will. You can F1 to continue through POST error (40) and you can basically plug-and-play drives after. I usually do the ribbon first, then power.
The internal AND the external will BOTH be A: in this situation. You will need an older board with "Swap Floppy Drives" or similar option to make the internal drive "B:" so the USB drive can get it's letter properly. They probably conflict right now. This is what I think is happening, anyway. I still don't have a USB floppy to play around with to work some of the common issues.
The 5.25 is "A:" proper if you power on with the USB floppy removed?
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 9 of 16, by jakethompson1
Yes, when you enable FDC and set a floppy drive in BIOS, that info gets passed down to Windows, which should cause the A: drive to appear in the UI.
Windows 10 does still support FDCs. I have never tested 11.
Reply 10 of 16, by SVslw
It moves its head on startup of MB, but a LED isn't on. This FDD worked perfectly with Socket 7 motherboard & was set up as A:
Reply 11 of 16, by SVslw
Major Jackyl wrote on 2025-02-13, 22:58:
Indeed it will. You can F1 to continue through POST error (40) and you can basically plug-and-play drives after. I usually do th […]
Seems like floppy controller doesn't work at all, I don't get any errors on startup. I don't really think the reason is a conflict with USB drive - win10 didn't see the drive anyway even without USB FDD connected
Reply 12 of 16, by jakethompson1
SVslw wrote on 2025-02-13, 22:59:
This board doesn't do a floppy seek in the traditional sense, and there's no option to enable one, so that's normal. With my 3 1/2 drive it just makes a brief click.
Reply 13 of 16, by SVslw
Oh and this 980DE3/U3S3 is glitchy as hell, the sound isn't working for me and USB's weren't working for another person who had this MB. Looks like a problem with Southbridge or Northridge.
Reply 14 of 16, by SVslw
jakethompson1 wrote on 2025-02-13, 23:02:
Thanks for info
Reply 15 of 16, by SVslw
I have a spare 970De3/U3S3 laying around as well, though I don't know if it's working.
Reply 16 of 16, by jakethompson1
SVslw wrote on 2025-02-13, 23:03:
Not specific to your board's issues, but under Linux, access to the floppy will glitch out. If you force PIO instead of DMA (floppy=nodma or such) you still get some spurious IRQ6 but it does work. There is some chipset errata about the LPC DMA but nothing about the IRQ6. There are also spurious IRQ4 if you use the serial. It gets worse when there is a lot of PS/2 mouse activity while using the floppy or serial. I reported it to the kernel bugzilla but it never went anywhere. Seems it's just a marginal Super I/O implementation or chipset errata on a last-of-its-era implementation like this is.
