First post, by khull-khumm
When I run blood 1 i get an "error":
14 memory used.
LOW MEMORY WARNING: Blood requires 23mb o free space memory
You may experience problems when runing Blood with low memory
Press a key to enter Blood...
And when I start the game there is no music. It's pretty strange because on setup everything works fine. I have much free space on hard disk too...
What could be the solution of this problem?
EDIT:
DOSbox 0.72
Reply 1 of 17, by MiniMax
Rank Moderator
Moderator
I believe DOSBox starts out with a default of 16 MB of memory. Change it in the DOSBox config file using Notepad.
Check the result with the MEM command inside DOSBox.
_________________
Reply 2 of 17, by khull-khumm
Ok, I changed memory size but there is still no music. I've checked setup few times and everything is ok there 🙁
Reply 3 of 17, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 17, by wd
Rank DOSBox Author
DOSBox Author
How did you configure the sound then?
Reply 5 of 17, by khull-khumm
SoundFX:
Sound Blaster or Compatible, 0x220, irq 7, 8bit-dma 1, 16bit-dma 5, 32 voices, 16 bit mixing, stereo sound, 11 khz
Music:
Sound Blaster
I can hear test sound effects and test music but the latter isn't playing in the game.
Reply 6 of 17, by Qbix
Rank DOSBox Author
DOSBox Author
did you mount your cdrom with the right flags ? Thought it had cdaudio.
Water flows down the stream
Reply 7 of 17, by khull-khumm
If you mean this:
mount f f:\ -t cdrom -ioctl -usecd 0
yes, i mounted it.
Reply 8 of 17, by wd
Rank DOSBox Author
DOSBox Author
Try mount d f:\ ...
or, if that doesn't work, reinstall the game while sticking to one mount configuration.
Reply 9 of 17, by tannerstevo
If you are running Vista, you might try mounting your cdrom using the -noioctl flag.
Also, if you run the game with no cd, it should still have background music, it just plays the cd audio if the cd is present.
Reply 10 of 17, by khull-khumm
I am using XP. Music is still not playing without CD.
Reply 11 of 17, by wd
Rank DOSBox Author
DOSBox Author
um yeah and don't just read the last response, but well, who cares
Reply 12 of 17, by leileilol
It has both CD audio and MIDI audio, and the tracks are not identical.
FUCK "AI"
Reply 13 of 17, by tannerstevo
Well, I just took a look at this and found that if I set music to soundblaster, I got no music in game. If you set music to general MIDI, it should work.
Reply 14 of 17, by leileilol
You should probably not use the Sound Blaster Clone type and select Sound Blaster 16 for sound effects then pick the same for MIDI.
FUCK "AI"
Reply 15 of 17, by ADDiCT
Are you playing from a mounted image (Daemon Tools) by any chance? If that's the case, try mounting the image with DOSBox' "imgmount" command.
Reply 16 of 17, by khull-khumm
Everything's fine now. I wrote -nocd command.
Reply 17 of 17, by wd
Rank DOSBox Author
DOSBox Author
Are you using a real cd, some externally-mounted image or the imgmount command?
