Reply 1320 of 2029, by blindy137
I saw similar behaviour with my PicoGUS 1.1. Tried several (previously working) firmware versions with corresponding pgusinit - no success.
As I could not resolve the issue that way, I installed another Pi Pico and everything worked again.
I know that is not an option with PicoGUS 2.0.
As I'm not that experienced with the Pi Pico yet, I cannot tell if the other Pico is damaged in some way.
Is there some recommended way that I could check the Pico?
