Reply 29240 of 31482, by Trashbytes
- Oldbie
yourepicfailure wrote on 2025-02-15, 08:50:gerry wrote on 2025-02-14, 10:26:yourepicfailure wrote on 2025-02-14, 06:38:Someone gave me this scope the other day. […]
But it's got some issues. Learning how to disassemble it so I can test caps.
Will probably have to wait a little to open the CRT driver side.Either way, this bohemoth is perfect for what I like to play with: old video equipment and old computers.
what a wonderful thing! Sure it will need some attention but hopefully you'll soon have it up and running, good as new
What I love is that everything is BNC, which 90% of the stuff I work with (old video equipment) uses by default. Makes connections so easy with BNC patch cables.
Otherwise, any recommendations when disassembling and troubleshooting it?
Take great care, I doubt itll be easy to replace the more delicate internal parts and components, the screen might be the hardest part to replace so its good you are leaving that part alone. I would recommend finding someone with old CRT knowledge they can be tricky to work with blind.
