MSI MS6905 ver 2.3 "Master" slotket with weird mod
Reply 40 of 71, by shevalier
bloodem wrote on 2025-02-10, 18:11:
I don't usually like doing this to retro parts but, in my defence, I was having a lazy day when I did it 😅 ).
You can always drill the board
PS. The Vtt voltage is often made by a regulator, independent of the core voltage
For example, LT1086.
Therefore, it is easier to connect VttPwrGD with Vcc.
DynOE must be powered from Vtt.
Otherwise, the CPU will not set the BSEL (bus frequency selection) and ViD (voltage selection) status.
Otherwise, get ready for surprises - for example, an attempt to start on bus 133MHz with a voltage of 1.3 Volts.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 41 of 71, by BitsUndBolts
bloodem wrote on 2025-02-02, 13:12:
I got my hands on yet another MSI 6905 ver 2.3 slotket (as if I didn't already have enough of these 😅 ).
I have seen you over on the AmiBay forum where you seem to have gotten your hands on an MS-6905 V2.4 Slotket.
Since I am still new to this forum (at least I still can't send PMs), could you please contact me? I have a few questions if you don't mind.
Thanks!
Reply 42 of 71, by bloodem
BitsUndBolts wrote on 2025-02-17, 08:47:
Thanks!
Sure, PM sent! 😀
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 44 of 71, by bloodem
PARKE wrote on 2025-02-17, 13:28:
Does a Ver 2.4 exist ?
No, I think BitsUndBolts confused the version number, I don't think there ever was a 2.4 version.
Reply 45 of 71, by PARKE
Ok, thanks. I try to keep my info up to date.
Reply 46 of 71, by BitsUndBolts
bloodem wrote on 2025-02-17, 13:31:
I guess I got confused with version 2.4 - this version was mentioned in a thread on AmiBay.
That doesn't exist apparently 😀
I got your PM, unfortunately, I am too new and cannot answer directly.
Could you send me another message and include an email I could reach you?
Alternatively, you can send a message to my email bitsundbolts at gmail dot com.
Thanks,
Alex
Reply 47 of 71, by bloodem
BitsUndBolts wrote on 2025-02-17, 17:24:
Will do. 😀
Reply 48 of 71, by mockingbird
I just wanted to provide a final update - my Nehemiah is perfectly stable (12 x 100Mhz FSB) with my new slotket. I ended up using an FX5200, and I made sure to disable SBA and FW (that is buggy even on other BX systems). With this combo I can run 3DMark 2000 forever and it will not crash to desktop.
So my conclusion is that the Abit Slotket iii is not a good choice for Nehemiah. You speculated that the reason could be because Nehemiah has newer features like SSE (and CMOV) that are placing extra stress on the slotket and require better voltage stability -- that could very well be the case. I have not tested with an older GeForce and older drivers, maybe it would be stable on those, but newer generation cards run much cooler and perform better.
I'm glad I was able to find a decent slotket.
(Decommissioned:)
Reply 49 of 71, by SWZSSR
I also have a MS-6905 with that cap fitted from factory. I'll have to get a pic.
LS486/5x86@180/Banshee/SoundscapeElite/DOS6.22
5TH/Dual233MMX/MGA2164W/Voodoo2/AWE64Gold/NT4.0&W9X
P5A(1.6)/K6-3+550/Ti500/EWS64XL/W9X
CUV266D/Dual1.4TUAL/HD4670AGP/XONAR/XP
780iFTW/QX9650/3x8800U/VISTAx64
Z87/4790K/TITANX/AuzBravura/XPx86
Reply 50 of 71, by PARKE
mockingbird wrote on 2025-02-20, 14:06:
Can you post a close up photo of that Abit slotket ? Thanks in advance.
Reply 51 of 71, by mockingbird
PARKE wrote on 2025-02-20, 14:25:
Certainly.
The attachment abitslotketiii.jpg is no longer available
My AA370TS arrived today and I'll be testing that with Nehemiah too if my second CPU ever arrives in the mail. It's currently running a sanity check with a Coppermine P3 at 6.5 x 100.
(Decommissioned:)
Reply 52 of 71, by PC Hoarder Patrol
Wonder how (if at all) the GTL2000 differs from the TVC16222 /16222A (that's the clamp IC on all my SlotKET !!!s)
Reply 53 of 71, by bloodem
mockingbird wrote on 2025-02-21, 03:35:
I've been busy and forgot to post an update.
I've also tested this slotket extensively with a Coppermine 900 MHz (FSB100) and a Coppermine 1 GHz (FSB133), and I was about to declare it stable (it passes every test, including hours upon hours of Prime95 and 3DMark2000), however, the system completely freezes in Quake 3 if... I bring down the console (this also happens right after launching the game, when accessing the console in the main menu). 😁
I can play Quake 3 for hours and it will work fine, but if I bring down the console, it usually freezes within the first minute (most of the times within the first 10 seconds). If I use the same CPUs with a different slotket, everything works fine, no console freezes. I even recapped it (though the original caps were still quite OK), but the behavior persists. I did not test the Nehemiah with it yet.
I'm curious if you will see the same behavior with your particular slotket + the P3 650.
Reply 54 of 71, by mockingbird
bloodem wrote on 2025-02-21, 16:50:
What did you use? Originals were 33uF, I put in 47uF.
Ok, I'll update you... For the AA370TS, I'm switching my testing from my FX cards back to the GeForce 4 MX440 (but still 45.23 drivers). Platform is P2B modded to get 3.3V for the AGP straight from the PSU. I want to rule out any issues I was having with the FX as the fault of the slotket.
(Decommissioned:)
Reply 55 of 71, by bloodem
mockingbird wrote on 2025-02-21, 19:21:
Same. 😀 Panasonic 47uF / 25V / Low ESR (EEUFR1E470).
Reply 56 of 71, by mockingbird
bloodem wrote on 2025-02-22, 05:29:
Well, my AA370TS is definitely unstable (Coppermine 6.5 x 100)... I tested with my Abit slotket for over 24 hours in 3DMark and that was perfectly stable, so it's definitely the slotket.
(Decommissioned:)
Reply 57 of 71, by PcBytes
I have an AA370TS too if there's need for help. Mine ran a Coppermine 1GHz (7.5 x 133) over an ABIT BE6-II last time I used it and it was perfectly stable.
Don't think I have any VIA CPUs left unfortunately, but for Coppermine I do have some chips. (Celeron 1100, P3 733, 866 so far)
Reply 58 of 71, by shevalier
Look at the socket on Intel's D815ee.
Inside there are many large ceramic capacitors of 4.7-10 uf.
Electrolytic capacitors with such an ESR (0.3 Ohm) will not give anything.
With such a socket PCB routing, you need something like 330uF * 6.3V up to 30-50mOhm.
Or polymer ones, of approximately the same value.
Reply 59 of 71, by mockingbird
shevalier wrote on 2025-02-24, 05:15:
Look at the socket on Intel's D815ee. Inside there are many large ceramic capacitors of 4.7-10 uf. Electrolytic capacitors with […]
Interesting suggestion, but if that's the case, then the slotket should also have these types of low-esr caps, and I don't know of a single one that does. I'd love to see someone design a new one.
(Decommissioned:)
