First post, by DosFreak
https://digital.darkhorse.com/pages/featured
There doesn't appear to be a way to download the comics permanently....
Effective February 24, 2025, we have closed Dark Horse Digital […]
Sales are no longer offered on the DHD website. But, you can still log in and read the comics in your bookshelf.
Support for the Dark Horse Comics and Plants vs. Zombies Comics apps for iIO will end March 31, 2025.
We encourage app users to download the books in their bookshelves by March 30, 2025. The ability to download to your device cannot be guaranteed after that date. For access through the website, users without DHD accounts should create one and sync it to the app by March 30, 2025.
We appreciate our fans and regret the inconvenience and disappointment caused by this news. We know you have questions so please go to our Frequentyl Asked Questions page for more information.
-The Dark Horse Digital Team
Make your games work offline
Reply 1 of 2, by SScorpio
There's a User Script that generates DRM free cbz files right from your digital library.
Their official response is access will remain through the summer. After that, it's whenever the server gets shutdown. Time to start scraping.
They already killed off the Android app last year. And it auto removed itself from my tablet. Welcome to the digital future.
Reply 2 of 2, by DosFreak
Thanks.
Before doing the below I was viewing the site in developer mode and copying out the urls manually and saving them. Bleh.
A combination of:
Librewolf
Tampermonkey
This script:
// ==UserScript==
// @name Dark Horse Downloader
// @namespace http://schiff.io/
// @version 0.3.1
// @description Download a DRM-free copy of your Dark Horse digital comics.
// @author Hayden Schiff (oxguy3)
// @match https://digital.darkhorse.com/read/*
// @match https://digital.darkhorse.com/bookshelf*
// @connect cloudfront.net
// @grant GM_xmlhttpRequest
// @require https://cdnjs.cloudflare.com/ajax/libs/jszip/3.1.3/jszip.js
// @downloadURL https://update.greasyfork.org/scripts/26635/Dark%20Horse%20Downloader.user.js
// @updateURL https://update.greasyfork.org/scripts/26635/Dark%20Horse%20Downloader.meta.js
// ==/UserScript==
* DARK HORSE DOWNLOADER
* Made by Hayden Schiff (oxguy3), license is Creative Commons Zero.
* This script makes it really easy to download a DRM-free copy of your digital
* comics on Dark Horse Digital. Simply go to your Dark Horse bookshelf at
* <https://digital.darkhorse.com/bookshelf>, then disable "Stack by Series" and
* switch to Gallery View if you haven't already. You will now see a "Download"
* button below all your comics.
* When you click the download button for any of your comics, it'll open the
* reader for that comic, then start downloading the comic. A red box in the
* middle of the screen will show you the progress of the download (be warned
* that things will be a bit laggy while it's downloading. Once it's done, a
* .CBZ file will pop into your downloads (if you aren't familiar, a .CBZ file
* is just a zip file full of JPGs. You can easily open it with a reader app
* or convert to PDF or whatever).
(function() {
'use strict';
var pagesDone = 0;
var pagesTotal = 0;
// from http://stackoverflow.com/a/10073761/992504
function padToFive(number) {
if (number <= 99999) {
number = ("0000" + number).slice(-5);
return number;
// from http://stackoverflow.com/a/15832662/992504
function downloadURI(uri, name) {
var link = document.createElement("a");
link.download = name;
link.href = uri;
document.body.appendChild(link);
link.click();
document.body.removeChild(link);
// This is part of a hack to use base64 to work around Greasemonkey's lack of support
// for responseType:blob on XHRs. Source: http://stackoverflow.com/a/8781262/992504
function customBase64Encode(inputStr) {
Show last 153 lines
        var
bbLen = 3,
enCharLen = 4,
inpLen = inputStr.length,
inx = 0,
jnx,
keyStr = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz" + "0123456789+/=",
output = "",
paddingBytes = 0;
var
bytebuffer = new Array(bbLen),
encodedCharIndexes = new Array(enCharLen);
while (inx < inpLen) {
for (jnx = 0; jnx < bbLen; ++jnx) {
/*--- Throw away high-order byte, as documented at:
https://.mozilla.org/En/Using_XMLHttpRequest#Handling_binary_data
if (inx < inpLen) bytebuffer[jnx] = inputStr.charCodeAt(inx++) & 0xff;
else bytebuffer[jnx] = 0;
/*--- Get each encoded character, 6 bits at a time.
index 0: first 6 bits
index 1: second 6 bits
(2 least significant bits from inputStr byte 1
+ 4 most significant bits from byte 2)
index 2: third 6 bits
(4 least significant bits from inputStr byte 2
+ 2 most significant bits from byte 3)
index 3: forth 6 bits (6 least significant bits from inputStr byte 3)
encodedCharIndexes[0] = bytebuffer[0] >> 2;
encodedCharIndexes[1] = ((bytebuffer[0] & 0x3) << 4) | (bytebuffer[1] >> 4);
encodedCharIndexes[2] = ((bytebuffer[1] & 0x0f) << 2) | (bytebuffer[2] >> 6);
encodedCharIndexes[3] = bytebuffer[2] & 0x3f;
//--- Determine whether padding happened, and adjust accordingly.
paddingBytes = inx - (inpLen - 1);
switch (paddingBytes) {
case 1:
// Set last character to padding char
encodedCharIndexes[3] = 64;
break;
case 2:
// Set last 2 characters to padding char
encodedCharIndexes[2] = 64;
break;
default:
break; // No padding - proceed
/*--- Now grab each appropriate character out of our keystring,
based on our index array and append it to the output string.
for (jnx = 0; jnx < enCharLen; ++jnx)
output += keyStr.charAt(encodedCharIndexes[jnx]);
return output;
function updatePagesDoneCounter() {
if (pagesDone % 5 === 0) {
document.getElementById("dhdl_status").textContent = "Downloading " + pagesDone + " of " + pagesTotal + " pages...";
// add download buttons to the bookshelf
if (window.location.pathname == "/bookshelf") {
// TODO: check if "stack by series" is enabled, and if so, don't add the download buttons
var books = document.getElementsByClassName("bookshelf-item");
for (var i = 0; i < books.length; i++) {
var book = books[i];
var btn = document.createElement("a");
btn.setAttribute("href", "/read/" + book.id + "#download");
btn.setAttribute("class", "button blue collection-read");
btn.setAttribute("style", "margin-top: 6px;");
btn.textContent = "Download";
book.appendChild(btn);
} else if (window.location.pathname.startsWith("/read/")) {
if (window.location.hash == "#download") {
// create box for showing status of download
var box = document.createElement("div");
box.id = "dhdl_box";
box.setAttribute("style", "background-color:#ffaaaa; border:2px solid #111; border-radius:5px; opacity:0.9; text-align:center; font-size:22px; width:400px; height:150px; margin:auto; position:absolute; top:0; left:0; bottom:0; right:0; z-index:10000;");
var boxTitle = document.createElement("h1");
boxTitle.textContent = "Dark Horse Downloader";
box.appendChild(boxTitle);
var boxStatus = document.createElement("p");
boxStatus.id = "dhdl_status";
boxStatus.textContent = "Starting up...";
box.appendChild(boxStatus);
document.body.appendChild(box);
var bookTitle = document.getElementById("bookreader-title").getElementsByTagName("h2")[0].textContent;
var bookTitleSafe = bookTitle.replace(/\s+/gi, ' ').replace(/[^a-z0-9 ]/gi, '_');
var pageUrls = [];
for (var i = 0; i < book_manifest.pages.length; i++) {
var page = book_manifest.pages[i];
var url = window.location.protocol + "//" + window.location.host + book_manifest.base_url + page.src_image;
pageUrls.push(url);
pagesTotal = book_manifest.pages.length;
updatePagesDoneCounter();
// reverse order for right-to-left books (i.e. manga)
if (book_manifest.is_rtl) {
pageUrls.reverse();
var zip = new JSZip();
Promise.all(pageUrls.map(function(url, index) {
return new Promise(function(resolve) {
GM_xmlhttpRequest({
method: "GET",
url: url,
onload: function(response) {
zip.file(padToFive(index) + ".jpg", customBase64Encode(response.responseText), {
base64: true
pagesDone++;
resolve();
overrideMimeType: 'text/plain; charset=x-user-defined'
})).then(function() {
document.getElementById("dhdl_status").textContent = "Creating zip file...";
zip.generateAsync({
type: "blob"
}).then(function(content) {
document.getElementById("dhdl_status").textContent = "Done!";
downloadURI(URL.createObjectURL(content), bookTitleSafe + ".cbz");
setTimeout(function() {
document.body.removeChild(box);
}, 3000);
and viewing the bookshelf in Gallery view enabled the Download button to appear for each comic.
