Reply 20 of 78, by megatron-uk
MAZter wrote on 2025-02-24, 13:54:I recommend to reflash bios first: […]
https://web.archive.org/web/20220531051143/ht … ds/4520tv67.exe
If this not helps, you can try to cleanup password using LPT port adapter:
https://www.youtube.com/watch?v=y4dMmZsG0is
My opinion if laptop boot slow and tsetup.exe does not do anything, something wrong with bios or you got bad memory chip (needs to test with MemTest86). 98048KB is weird amount of memory.
I have 510CDT with secondary HDD adapter and it boot pretty fast even without main HDD installed.
USB flash drive works acceptable in MS-DOS using drivers.
The memory is a pretty normal figure for one of these - that's the total for 32mb onboard plus a 64mb expansion.
A bios flash is definitely worth a try though.
https://www.target-earth.net
