Reply 56180 of 60053, by RetroPCCupboard
Got this with a box of PC parts:
The attachment 20250225_124448.jpg is no longer available
The attachment 20250225_124501.jpg is no longer available
The attachment 20250225_124525.jpg is no longer available
Compatible with DOS/9X/XP. It might be a useful card for my test bench. Not sure I'd use it in a build though. But will be interesting to test it out.
I see Philscomputerlab did a video on this chipset
https://youtu.be/oHKa-TE-U4Y?si=V3PajWwpResqrDuk
Reply 56181 of 60053, by PcBytes
Bought a Celeron 300A along w/ GPU, mobo and a Realtek RTL8029 (I think) NIC. Mobo is a Jamicon 643L-AT.
Reply 56182 of 60053, by PD2JK
So I decided to take part of the Radeon R3x0 lottery. Guess how this 9800 Pro is behaving. Bumped my nose again.
The attachment DSC_3310.JPG is no longer available
Maybe a little heat to the RAM chips will suffice...
has all kinds of stuff
Reply 56186 of 60053, by cyclone3d
RetroPCCupboard wrote on 2025-02-25, 19:36:
Lostdotfish wrote on 2025-02-25, 18:43:
Wish I saw that. Bargain if the SLI Voodoos work.
And is that a GeForce 256 DDR or SGRAM?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 56187 of 60053, by Kahenraz
I saw that someone found a SLI pair in a vintage laptop dock here a while ago. That was pretty wild.
Reply 56189 of 60053, by Kahenraz
MAZter wrote on 2025-02-26, 18:10:
https://www.ebay.com/itm/176876846590
A PDA (or organizer) that fits in a PCMCIA slot
Oh, that's super cool. Could you please post more photos of it in action once you get it? Or a video if possible. It uses a coin cell, so you'll never have to worry about a proprietary battery going bad.
How far of a date does the calendar support? It looks like you use the little arrows to navigate. Or is it a touchscreen? Does that mean it has an onscreen keyboard or is it programmed by the computer and is effectively a "read-only" organizer when held? Maybe it needs drivers and a companion application then.
Very cool and super niche that it stores in a PCMCIA slot. I'd have totally used something like this as a kid if I had one.
Reply 56190 of 60053, by MAZter
Kahenraz wrote on 2025-02-26, 18:49:
Sorry, I actually gave someone else the opportunity to buy this 🤣
Reply 56191 of 60053, by Kahenraz
My mistake. I thought you were posting something that you bought it. I hope the new owner enjoys it.
I sent a link of the PDA to a friend and wanted to share his response:
Looks like it needs to be fed like a tamagotchi.
Reply 56192 of 60053, by shamino
bought a Memorex 52X external USB 2.0 CDR drive at a local thrift store:
The attachment driveEnclosure.jpg is no longer available
The front bezel is completely open, and it has a real power supply providing 12V+5V, (not just USB powered), so my hope was that I can swap a DVD drive into this enclosure. It was made in 2004.
The attachment enclosureLabel.jpg is no longer available
The box had all the hookups and still had the "free" sealed CDR disc in it. I think all that was missing was the disc of Nero/etc bundleware.
The attachment boxpic-eatCDs.jpg is no longer available
Other than 2 screws, which were surprisingly not tight, the rest of the case unsnaps. Of course I didn't do it quite right. I got the front off, but after I got one side of the lid to lift, I hinged the other side the wrong direction causing it to break.
The drive itself is held in with 2 more screws (also not tight) hidden under the front pair of rubber feet.
The attachment ATA-USB2-adapterPCB.jpg is no longer available
The internal drive is IDE/ATA, not SATA.
The attachment unusedJumpersConnectors.jpg is no longer available
The adapter PCB has some unused solder points for LEDs and unknown jumpers. It also has a populated audio jack and power switch.
I swapped in a DVD drive and it does work. I copied a DVD from it without issue.
The drive I tried is physically too long for the enclosure though, so I need to find a shorter one.
I also bought a copy of "Starfleet Academy: Strategic Command" that was in the music CD area. I then dropped the case and broke it, because jewel cases are the most fragile things ever.
Reply 56193 of 60053, by Brawndo
Holy crap! That's at least $500 worth of PC there. Seller had no idea what they had.
Reply 56194 of 60053, by RetroPCCupboard
The attachment 20250227_103952.jpg is no longer available
Paid £40 for it. Not sure on official size but measuring inside bezel, corner to corner, its 15.75". Seems capable of up to 1280x1024, but 1024x768 seems a more comfortable resolution
Reply 56195 of 60053, by OVERK|LL
shamino wrote on 2025-02-27, 01:41:
bought a Memorex 52X external USB 2.0 CDR drive at a local thrift store: […]
I have an Iomega one that looks identical, except it has a DVD+/- RW in it. Works beautifully, so I assume you'll have similar luck.
DD: Mac Pro 5,1 - X5690, 64GB, RX 580 - OCLP w/Sequoia
Projects:
- Hewitt-Rand 8088 - 640KB, 20MB, Hercules mono
- IBM PS/1 2133 w/Thermalwrong solder mod - ODP 486DX4-100, 32MB
- PCPartner VIB806DS w/233MMX, 128MB, G450
- Jetway J-TX98B w/P75, 256MB
Reply 56196 of 60053, by kixs
RetroPCCupboard wrote on 2025-02-27, 15:42:
This is 17". Size is for complete diagonal of the screen that also includes what is under the plastic cover (case). True, 1024x768 is the optimal resolution.
Is there any sticker on the back for more info?
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 56197 of 60053, by RetroPCCupboard
kixs wrote on 2025-02-27, 17:27:
I thought it may be 17 based on the model number, but wasn't sure... This is sticker on back:
The attachment 20250227_173423.jpg is no longer available
Reply 56198 of 60053, by momaka
AGP4LIfe? wrote on 2025-02-24, 19:47:
Yea I noted two or three of the caps were very very slightly bulged. The card tested just fine through the stress test, but I'm sure it would be good to do so eventually.
Thanks for the extra motivation!
You're welcome.
Yeah, mine worked too, despite the bad caps. VRM is well-designed on this card. Of course I recapped it right away afterwards. Not going to risk it with the bad caps eventually taking out a MOSFET or coil.
devius wrote on 2025-02-24, 18:56:
Just above someone was mentioning having PTSD from Bestec PSUs 😁 I personally never used or even seen that brand before, so can't comment though.
It's an AT power supply, not ATX, so probably safe from their infamous Kamikaze 2-transistor 5VSB circuit found in the ATX-250-12E.
I have a number of ATX-250-12Z PSUs, and those are really solid 250W PSUs that can be used on both 5V-heavy Athon/XP PCs and Pentium 4 ministoves.
eesz34 wrote on 2025-02-24, 16:29:
New old stock 200W AT power supply came up for the price of a used low end ATX. I think these are good quality, has Nichicon caps. Just have to get the musty smell out of it!
Curious what else it has inside. 😀
I used to just dust used PSU when taking them apart and then called it good. But now I wash them completely (minus the fan). Just need to have sunny weather (and above freezing temperatures) so they can dry outside. The fan gets a separate scrub with wet wipes. Doing this gets rid of most "musty" / oldy-modly basement smells.
PD2JK wrote on 2025-02-25, 18:40:
No, it's the GPU chip that goes faulty on these, so reflow that instead. Don't even need to go to the full reflow temp - 160-180C will do about most of the time. If card is stubborn, do the reflow again.... and again.... 'till something burns. That said don't protect the RAM chips from the heat either, as they will be fine.
Oh, and after the 1st reflow, you can try popping out the metal shim on the GPU chip. The heat will make its glue easier to remove. Once that is gone, also get rid of the stock cooler and put something much bigger on there (Zalman VF700CU as minimum or other dual slot cooler preferred.) With some luck, that should help keep the reflown GPU working longer.
bought a Memorex 52X external USB 2.0 CDR drive at a local thrift store: .... download/file.php?id=213129&mode=view this picture […]
this picture confuses me
Some late 90's and early-mid 2000's computer images were seriously "WTF".
In regards to the power supply / power adapter: if it has screws, open it and check it inside. I don't know who Memorex used as the manufacturer in particular, but I do know that in the mid-2000's, there were a rash of these dual-output (5V, 12V) power adapters that were terrible for developing bad caps and doing awful things to the attached hardware. So I always try to check. If you want to do that before opening, see if the adapter has a UL number or if the model number reveals who the manufacturer is. If it's Delta, LiteON, or some other similar known OEM, I wouldn't worry.
Anyways, nice find! Those external drives are pretty handy to have, especially if you have a modern PC without an optical drive (not my case, most of my PCs are decade+ old.)
Nooooo, please don't run 1280x1024 on your CRTs.
If I had a magic wand, I'd make all CRT monitors refuse to run that resolution. It's the wrong aspect ratio (5:4)... and on top of that, this is usually the max resolution most 17" CRTs will do, often disallowing anything but 60 Hz for the refresh rate.
If you drop down to 1280x960 (which is the proper 4:3 resolution for a CRT), sometimes you will get the option to increase the refresh rate to 70 Hz, which is still miles better than a very blinky 60 Hz.
Reply 56199 of 60053, by RetroPCCupboard
momaka wrote on 2025-02-27, 20:32:
Haha. Don't worry. I wasn't planning to. 1024x768 seems optimal for this monitor.
