PCem Emulation is slow
First post, by OmriSh
I'm trying to emulate windows XP using these settings:
Gigabyte GA-686BX
Intel Pentium || / 400Mhz
512 MB
3DFX Voodoo 3 3000
Sound Blaster PCI 128
And it is leggy, even games such as jazz jackrabbit 2 or icy tower runs a bit leggy.
It shows a 100% emulation speed.
My PC Build:
Windows 11 Pro
MSI B650-S
AMD Ryzen 7 9700X
32 GB
RTX 3050
Why is it so slow? Is there a way to make it run smoother?
Reply 1 of 7, by DosFreak
Drop to a slower emulated processor.
If you want to use Windows XP instead of an older OS on the slower processor make sure you only install what is necessary including what service Pack is actually needed and do all the Windows tweaks.
If the games don't need pcem and work fine on the host or via virtualization not emulation then use that.
Make your games work offline
Reply 2 of 7, by BEEN_Nath_58
Jazz jackrabbit 2 worked fine on Win11 the last time I played
Otherwise consider using Win98 for your machine. A slower CPU should also be fine, like a Pentium MMX
Reply 3 of 7, by Norton Commander
512 MB is enough RAM to run Windows XP and nothing else because all it does is constant disk swapping. Up the RAM to 3 GB which is XP x86's memory limit. There was a PAE hack that allowed XP to access more RAM but I never tried it. Try installing XP Service Pack 2 since that's lighter than Service Pack 3 (It's what I used when I had a Pentium II 400MHz desktop).
Reply 4 of 7, by GemCookie
Norton Commander wrote on 2025-02-23, 12:20:
More like 64 MiB.
In PCem, the Gigabyte GA-686BX is limited to 512 MiB of RAM. Editing the c0nfiguration file to specify 3 GiB of RAM causes a crash when the machine starts up.
Gigabyte GA-8I915P Duo Pro | P4 530J | GTX 750 Ti | 2GiB | 120G HDD | 2k/Vista/10/FBSD
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/OBSD
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/XP/NBSD
Reply 5 of 7, by 9646gt
you should try 86Box! I have been having a blast with it. Only downside is that on Mac the 3dfx implementation can be buggy. It's like a modern and more updated for of PCem
Reply 6 of 7, by Battler
The 3Dfx implementation is buggy on all the supported host platforms, and the bugs are mostly inherited from PCem* - we have, if anything, fixed a number of them already, though several remain to be fixed.
* I could be wrong and there could be regressions introduced by 86Box itself, I certainly can't exclude that possibility.
Reply 7 of 7, by DosFreak
Closed, topic annoys me and the "issue" has likely been solved.
This is not a thread for all PCem issues, comparison of emulators, recommendation of other emulators or issues that do not involve the op.
