First post, by psychofox
I am not very familiar with MIDI connections. Could somebody help me?
I have an MMX PC build where the MP32 unit resides inside the PC case. The MIDI cable comes out the back of the case and connects to the DB15 MIDI/joystick port. It is not an elegant solution, but so far it has worked just fine.
Now I have the situation where I need to use a joystick as well. So, I thought I could connect the MP32 internally to the soundcard. My first thought was to solder the MIDI cable to the soundcard's rear side (on the PCB DB15 connections). But then I thought it might be possible to modify the MIDI cable and connect it directly to the daughterboard connector. This way, I can easily disconnect the MIDI cable if needed, and the soundcard remains unmodified. My question is: is the MIDI in/out signal on the daughterboard connector the same as on the joystick port?
I already searched for pinouts, but that confused me. I see there some differences: on the DB15 port, I see MIDI in/out labels, while on the daughterboard connector, there is only MIDI TTL.
Reply 2 of 3, by psychofox
Yoghoo wrote on 2025-02-27, 15:06:
Why not use a joystick Y cable or something like this: https://www.serdashop.com/DB15-Doubler-Solder-Kit ?
I think I am just bored 😀 ... I am aware of the splitter option. I think I have a Y DB15 cable somewhere around.
But seriously this build has 4 sound cards, and it is all fitted into a quite small minitower case. Four audio cables plus a MIDI cable come from the back to a 5.25 mixer device. It is a cable nightmare inside, so I am exploring options to clean it up a bit.
It is this build: Pentium MMX DOS gaming build "Bright Star"
Reply 3 of 3, by M-HT
MIDI TTL on the daughterboard connector is a 5V serial output and on the DB15 port it's probably the same.
These are the necessary connections:
5V pin on the daughterboard connector -> 220 ohm resistor -> pin 4 on the midi connector on MP32L
MIDI TTL on the daughterboard connector -> optional buffer (e.g. pair of inverters) -> 220 ohm resistor -> pin 5 on the midi connector on MP32L
The buffer is probably not necessary in this scenario.
Here are some links with specifications and explanations:
https://learn.sparkfun.com/tutorials/midi-tut … -implementation
https://midi.org/5-pin-din-electrical-specs
