Replacing DOS/4GW with DOS32A
First post, by sharangad
Hi
I'm trying to replace DOS/4GW from Indycar Racing 2 with Dos32A. I need to do this so the game can support more than 64 MB of RAM.
But I'm not having much luck. Unbinding produces a cart.lc file which won't run with Dos4GW or DOS32A:
V:\CR>dos4gw cart. lc
DOS/4GW Protected Mode Run-time Version 1.97
Copyright (c) Rational Systems, Inc. 1990-1994
DOS/4GW fatal error (1008): can't load executable format for file CART.LC [1]
V:\CR>dos32a cart. lc
DOS/32A -- Protected Mode Run-time Version 7.35
Copyright (C) Supernar Systems, Ltd. 1996-2005
DOS/32A fatal (3006): exec format not supported in file "cart.lc"
Does anyone know how I can deal with this. I'm looking through the disassembly of DOS32A, but it's slow going.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1 of 25, by vstrakh
Back in the day I'd replace DOS/4GW with PMODE/W, it includes the tools to bind/unbind the stub.
Reply 2 of 25, by sharangad
vstrakh wrote on 2025-03-02, 10:52:
Dos32a came with sb. Exe which does the same thing, but it doesn't seem to correctly identify the exe type.
Reply 3 of 25, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It should work with LE (Linear Executable) format, but not sure if .LC is the same... maybe compressed?
Reply 4 of 25, by BloodyCactus
ripsaw8080 wrote on 2025-03-02, 21:39:
"LC" is DOS32A's variant on a compressed LE/LX file, or its intermediary file format when you bind sometimes.
Reply 5 of 25, by sharangad
Even running directly fails with:
V:\CR>dos4gw cart.exe
DOS/4GW fatal error (1008): can't load executable format for file CART.EXE [1]
V:\CR>dos32a cart.exe
DOS/32A fatal (3006): exec format not supported in file "cart.exe"
It's almost like Dos4gw is static linked into the game.
Reply 7 of 25, by sharangad
I've figured out why SB.exe isn't working.
The first exec section is an MZ which is incompatible, the second is a BW. SB.exe, which replaces the stub doesn't test to see if the second exec is BW; if the first is incompatible it looks for LE, LX and LC as the second exec, but not BW, which is a supported type.
Reply 8 of 25, by sharangad
Base MZ, extended , start 00000000, size 0000F474
Base BW, extended , start 0000F474, size 008FB400
The second exec is a PE/COFF or whatever but there's no sign of an LX, LC or LE in there.
Does this mean Dos4gw is statically linked?
Reply 9 of 25, by wbahnassi
A hint would be to check the file size. Is the exe so large it could house a DOS4GW.exe in it?
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 10 of 25, by BloodyCactus
BW are watcom EXP's. I think run386.exe runs them. fading memories but they mighty be pharlap or causeway extender files. You used to see the more with DOS16M instead of DOS4GW.
dos4gw should still be able to load a BW.
Reply 11 of 25, by sharangad
BloodyCactus wrote on 2025-03-04, 13:11:
Well it's the second exec, the first is a 64kb mz.
Dos4gw and dos32a can't run it.
[edit] it only runs with it's built-in dos4gw in the 2nd exec. I have a bad feeling I can't replace the built in one with dos32a. The dos4gw binary and the actual game seem to be merged together.
Reply 12 of 25, by BloodyCactus
use UNP utility to copy off the overlay then rebind (copy /b newstub.exe+overlay.bw newexec).
Reply 13 of 25, by sharangad
BloodyCactus wrote on 2025-03-04, 14:07:
I'm a bit new to this, the stub from dos32a is the mz section from dos32a. Exe?
[edit]
Also which extender does unp come with? Dos32a comes with sb. Exe.
Reply 15 of 25, by sharangad
V:\UNP411>unp o v:\cr\cart.exe v:\cr\cart.ovl
UNP 4.11 Executable file restore utility, written by Ben Castricum, 05/30/95
processing file : V:\CR\CART.EXE
DOS file size 1247899
file-structure executable (EXE)
EXE part sizes: header 512 bytes, image 62068 bytes, overlay 1185319 bytes
action: copying overlay ... done
new file size: 1185319
writing to file : V:\CR\CART.OVL
V:\UNP411>cd \cr
V:\CR>dos4gw cart.ovl
Illegal command: dos4gw.
V:\CR>dos32a cart.ovl
DOS/32A fatal (3004): exec format not supported in file "cart.ovl"
[EDIT] Running cart.exe does work with its own dos4gw, embedded into the overlay.
[EDIT2] How can I extract the stub from dos32a?
[EDIT3] Nm, Dos32A comes with a stub:
V:\CR>copy /b v:\dos32a\dos32a\binw\stub32a.exe+ v:\cr\cart.ovl v:\cr\cart2.exe
STUB32A.EXE
CART.OVL
1 File(s) copied.
V:\CR>cart2
DOS/32A fatal (3006): exec format not supported in file "V:\CR\CART2.EXE"
Reply 16 of 25, by BloodyCactus
weird. it should have worked. Ive done this many many times before.
Reply 17 of 25, by sharangad
Does anyone know if there's any documentation for watcom exp binary formats. I seem to be struggling to find anything. I'd like to try converting it to an mz/LE if possible .
Reply 18 of 25, by M-HT
sb.exe utility has wrong algorithm for finding executable headers. Instead of finding LE header at offset 0x28C9C, it finds what it thinks is a LC header (but it's not) at offset 0x7A35B.
You must unbind the linear executable manually, then you can bind it (using sb.exe) to dos32a.
Here is my algorithm to find the linear executable header.
Reply 19 of 25, by sharangad
M-HT wrote on 2025-03-07, 08:57:
Thanks will give that a go as soon as I get back to my desk.
