Reply 20 of 258, by DustyShinigami
- l33t
Grzyb wrote on 2025-03-02, 13:06:DustyShinigami wrote on 2025-03-02, 12:09:Regarding SHSUCD - can it be used to load physical CDs as well? Or is it purely images?
SHSUCDX is supposed to be an MSCDEX substitute - so yes, it should work with real drives as well.
That's what I thought. Although I've not had much luck getting it to work yet. I could be wrong, but don't you need to specify the path of an image? When you initialise SHSUCDHD? That loads the device driver and then when I've set up SHSUCDX, it assigns the drive to E by default. At least for me. I presume there's a switch/command to specify what drive you want it to be? So instead of E it will be F etc?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
