First post, by theelf
Hi guys, im in a middle of a working trip, and i dont have any old computer near me, and i dont trust dosbox or pcem to test a code im writing in asm
The code just change in mode 80x25 from 720x400 9x16 font to 640x400 8x16, but like i said i cant test in real hardware until next week i return home, but i will love to continue coding if i know works
First print a 9x16 text, then after press enter, it will display a 8x16 one, if working of course
Thanks in advance for test, and to let me know the video card you tested
Reply 1 of 11, by amadeus777999
I got this...
after hitting return a blank screen, and after hitting return again I'm back at the prompt.
Reply 2 of 11, by theelf
amadeus777999 wrote on 2025-02-28, 20:39:
I got this...
thanks a lot! very helpful
ok, the small exe what do is print "hello this is is a test of 9x16 font" then wait for a enter, and should be print "hello this is is a test of 8x16 font"
if not, is not changing to 8x16 640x400
Reply 3 of 11, by Grzyb
Testing on this hardware:
The attachment hw.png is no longer available
First, I get this:
The attachment before.png is no longer available
After ENTER - empty black screen, without even the blinking cursor.
Nie rzucim ziemi, skąd nasz root!
Reply 4 of 11, by theelf
Ok thank guys then the code is not working in real hardware
thats good to know then i dont need to keep losing time with this line of the code
Im still thinking if is possible to disable 9bit for 80x25
Reply 5 of 11, by Kalle
I got both texts, but they look the same to me, it didn't seem to have switched, the monitor reports 70Hz for both.
Tested on an nVidia Vanta LT in MS-DOS 6.22.
Reply 6 of 11, by theelf
Kalle wrote on 2025-03-01, 20:55:
thanks definitive test for me, since i have a riva 128 in my DOS computer
thanks a lot!!!
Reply 7 of 11, by Kalle
You're welcome. Out of interest I also took a deeper look at it and experimented with it. What you see in the screenshots is what you want, right?
From what I understood, this is what you have to do:
- Reset the sequencer, changing the clocking mode reg to a character width of 8 (3C4h to 1, 3C5h to (3C5h or 1))
- Set the char width of 8 in the pixel panning reg of the attribute controller (read 3DAh to prepare it, then write 13h, 0h and 20h to 3C0h)
- Set the misc output reg to the 25MHz pixel clock (3C2h to (3CCh and 0F3h))
Reply 8 of 11, by theelf
Kalle wrote on 2025-03-02, 11:22:
You're welcome. Out of interest I also took a deeper look at it and experimented with it. What you see in the screenshots is wha […]
- Set the char width of 8 in the pixel pannel reg of the attribute controller (read 3DAh to prepare it, then write 13h, 0h and 20h to 3C0h)
Oh man yes this is what i want, but since i did not jave right now my computer i did not have chance to do some trial and error
You made what i was looking for! did you do in asm?
thanks a lot for test, interest and help
Reply 9 of 11, by theelf
i made a second test following your advice, will be possible can you check? thanks a lot
Reply 10 of 11, by Kalle
Yes, it switches fine on my computer now 😀
Reply 11 of 11, by theelf
Kalle wrote on 2025-03-02, 14:24:
Thanks a lot man, your advice was great, i did not need much more to correct asm code
Im happy to find all nice people like one in this forum
Im making a small game for DOS in text mode, and i was thinking to avoid the horrible 9x16 black line effect
