First post, by Theletterf
Hi there,
I'm assembling a Pentium IV PC from spare parts. I'm trying to connect a Sony MPF920 1.44 MB floppy drive and a Chinon FR-506 1.2 MB unit for the 5¼ floppies. The motherboard is an MSI 865PEM2. All parts are known to work independently.
The FDD ribbon cable has both standard and EDGE connectors for units A and B. When I plug either the Sony or the Chinon as A, leaving the other unit out, they both react well to POST tests and floppy seek. When I try plug one of the drives as B, they aren't detected and the infamous error 40 appears. No lights, no sounds, nothing. This cable, and the units, previously worked when plugged to a different motherboard.
At this point, I'm not sure whether this is a cable issue or a motherboard problem. Have you ever faced a similar issue?
Thanks,
F.
