First post, by Luger
Hello!
Can I ask for help in setting up DgVoodoo2 for one specific game? I found an old Chinese RPG, but I can't set it up to work properly under Windows 10 🙁
The screen is either completely black or flickers.
If it's not too much trouble, please help!
Game 花神传说 (Flower Story)
Link https://dropmefiles.com/FdyDP
Reply 1 of 10, by feda
The copy you linked came with a preconfigured copy of ddrawcompat. It worked fine on my end after running detectvga.exe and then mapset2.exe. Dgv is not needed.
Reply 2 of 10, by Luger
feda wrote on 2025-03-03, 08:03:
Yes, I put ddrawcompat there myself. And it works. But with one problem, when trying to close the game with the "exit" button, the game freezes. There is definitely no such problem with DgVoodoo2.
Reply 3 of 10, by feda
Okay...
Is that important? You can just use task manager.
Reply 4 of 10, by Luger
feda wrote on 2025-03-03, 08:16:
Okay...
Yes, it is possible. But I am afraid that this may be just the tip of the iceberg of problems. And I would like to make the most well-functioning repack
Reply 5 of 10, by Dege
Luger wrote on 2025-03-03, 07:45:
Hello! Can I ask for help in setting up DgVoodoo2 for one specific game? I found an old Chinese RPG, but I can't set it up to wo […]
Hello!
That is because of a bug in dgVoodoo, it will be fixed in the next version.
Reply 6 of 10, by Luger
Dege wrote on 2025-03-03, 20:40:
Thank you! I look forward to the update 😀
Reply 8 of 10, by Luger
Dege wrote on 2025-03-05, 21:49:
I released a tiny WIP build, ddraw.dll included, to test:
https://dege.fw.hu/temp/dgVoodoo_2_84_1_fixes.zip
Yes 😀 This problem is gone! Thank you very much. But can I bother you a little more?
The thing is that in the game with dgVoodoo2 the cursor is doubled. With the help of the parameter SystemHookFlags = cursor you can solve this problem, but in this case the original cursor icon disappears.
They helped me break the game exe a little and now the intro video works 😀 But it does not scale to the whole screen with dgVoodoo2 🙁
Here is a link to the game with a working video, please take a look, is it possible to fix this somehow.
https://dropmefiles.com/IwLgT
Reply 9 of 10, by Dege
Luger wrote on 2025-03-06, 10:47:
Yes :) This problem is gone! Thank you very much. But can I bother you a little more? The thing is that in the game with dgVoodo […]
The cursor problem is kind of known, I ran into it with other games too.
The video playback works with default dgVoodoo config: no resolution forcing and "unspecified" scaling mode.
That's the only way to keep the window size 640x480 which is expected the video player (which does not use DDraw for the playback btw).
It's not a thing that I can easily "fix".
Reply 10 of 10, by Luger
Dege wrote on 2025-03-11, 19:19:
The cursor problem is kind of known, I ran into it with other games too. […]
Got it. Thank you very much for your help!
