Reply 100 of 113, by Major Jackyl
- Member
I worked on this yesterday:
I usually use this and this to test boards:
But I thought I could have a more permanent solution.
My "modern" computer is up high and the case buttons are even higher. My wife is unable to reach hers without a stool. I'll be able to use this not only for testing, but total FP relocation. I'm currently out of beepers, so I can't put one in yet, but my test beeper fit, so it should be a workable item. Left room for a turbo/AUX LED, could be useful.
The LEDS fit very nice. Different switches I tried fit only slightly differently, but all fit pretty tightly. The buttons also seem to grab the cores well, so it's just pressed together and has good action. I was going to hot-glue it all in, but it's tight, so I'll conserve the glue. I rotated the zip-tie holder already, so only one will be needed (didn't even think about that, 🤣)
I wonder how it's going to print on other printers? The STPs I generate tend to be more reliable, as Inventor 2012 can leave the exported STL files with weird geometry. Creality Print(5.0) never has the right scale when I use my own generated STLs, only the STPs come out perfect every time. I'm pretty satisfied how it turned out.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
