Reply 740 of 832, by PC@LIVE
- Oldbie
I was curious to see the Chaintech 5TDM2 in operation, so recently, I recovered an i133 CPU (Pentium P54), which was on a P5F76 that I have among the MB to fix, I put on the 5TDM2 a couple of RAM 72 PIN of 8MB each, which I had many years ago on my PCs, for the post card, I used this time my Riser ISA, it allows horizontal mounting of the cards, in this way you can see better, both the codes and the LEDs, after connecting everything else, that is, the video card power supply etc..., I try to start.
Initially, it seems to want to start, you see a code appear on the post card, the code displayed is C0 —, so it crashes, while every subsequent restart attempt, it doesn't show any code, for now apart from a few attempts without CPU and RAM, which give the same result, I'm rearranging the ideas, what to try.
While the card was in operation, I checked the voltages on the Mosfets, there were three Mosfets, and all had correct voltages, two about 5V and one about 3.3V, so I think that the voltages are correct, and that the problem may not be hardware, because the recognition of the CPU is automatic, and if something is wrong, there is no possibility of switching to the manual (via jumper), for now I just do some tests with different hardware, another CPU other RAM, maybe you could unlock, I hope to get some results, because I would like to see this card in operation.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
