Reply 20 of 40, by spacesaver
Alright, I've placed orders for both 5500 and 5000 parts. I actually had already ordered a 5000 board on 2/8, seeing it was cheap. But then hesitated after eisapc suggested 5500. I actually found 5000 easier because there's no separate power cables, power switch, or power backplane (not a fundamental issue because I probably can make a substitute). I also found full 5500 systems for sale. https://www.serverworlds.com/hp-proliant-5500 … proliant5500pro, but it was too late.
Also 5000 does support the more common EDO RAM. This says
the 219286-001 board supports both. I haven't seen any other memory board mentioned, so it seems EDO & FPM is more common than FPM only.
https://www.kingston.com/unitedkingdom/en/mem … iant-5000-6-200
If the system has a serial date number X706 XXXX XXXX (or lower) or has been purchased prior to February 1997, it will require a BIOS version E16 and FP/EDO memory conversion kit (219481-B21 or 219286-001) available from Compaq.
------------------------5500 minimum parts-------------------------306561-001 motherboard306582-001 (2) CPU board219209-001 (4) VRM, 40Wor296203-001 (4) VRM, 48W got this270183-001 memory boardEDO, buffered, ECC DIMM, size <= 512MB. Must be installed 2 at a time and with the same timings169286-002 power supply328708-001 power cables306571-001 power backplane328710-001 power switch271930-001 diagnostics display------------------------5000 minimum parts------------------------219287-001 motherboard219448-001 or 219447-001 (rack) power supply219409-001 (2) CPU board219388-001 CPU board terminator sounds useful for testing and because I probably don't want to buy all 4 PPro CPUs at the same time219209-001 (4 + 2 for motherboard) CPU VRM, 40W didn't see an option for 48W needed for the fastest PPro with 1 MiB cache219286-001 (2) memory board199819-001 Remote Insight allows seeing POST codes; not bought yet, but sounds usefulEDO, buffered, ECC DIMM , size <= 256 MiB. Must be installed 4 at a time and with the same timings
