Reply 760 of 832, by PC@LIVE
- Oldbie
Before reprogramming the Chaintech 5TDM2 BIOS chip, I did some tests, to see if I could find a way to start it, despite some attempts, it remains stuck on the codes — —, as if there was no activity, in reality there is some sign of activity, but it is a continuous attempt to do something, maybe it could be an attempt at BIOS recovery (?), in any case by today I should remove the doubt, that the BIOS present in the chip is more or less good (?).
I checked the program, and the type of ATMEL chip is among those that can be read and written, so I would have to save the content, so that I can restore the content, in extreme cases of possible problems, although I imagine it is useless, in case updating it the card comes back to work, this means that the stored BIOS is damaged or defective.
If I succeed with Chaintech, I will try to recover other MBs, which are apparently broken, in fact in some I have not found anything that is broken, and therefore it could be a software defect rather than hardware.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
