Reply 56300 of 59294, by Shponglefan
- l33t
65C02 wrote on 2025-03-10, 23:52:And isn't the 1280x1024 resolution difficult to cleanly scale to (unlike 1600x1200, 1920x1200, or 4K)?
I like the idea of a retro themed LCD, but the 5:4 panel doesn't seem like the best choice for it.
Agreed. This was one of the common questions/complaints as to why they didn't use a 4:3 panel.
Mind you, it does do proper 4:3 aspect ratio with letterboxing. So in theory this gives you a 1280x960 display which at least can scale into 640x480 and 320x240.
However, this also assumes that image smoothing can be turned off. By default it does seem to be applying some image smoothing, so I'll have to see if there is a way to disable that.
edited:
Just tried Gateway (640x480 DOS game) and it is blurry due to image smoothing. This is a close-up of the image:
In comparison, here is a shot of a Dell 2007FPb:
