Video Problems
First post, by Unregistered
I understand that VDMSound is concentrated on sound issues, but I thought maybe someone here could help me out. On a number of different old games that use Vesa (Capitalism, Mugen, Transport Tycoon) I just can't get them to work no matter what I do. I run the games under VDMSound, and the sound in fact works just fine, but the screen is all jumbled, and it looks like the graphics card is accessing only a portion of the video memory and then making it full screen. (Stuff is big, but lines don't line up because it truncates the rest of the screen). I don't know why this is happening, and maybe it's an issue with my video card, although they worked with the same card under Windows 98.
My System:
1.33ghz AMD Athlon
512mb DDR RAM
3DFX Voodoo 5 graphics card
AmigaMerlin 2.1 video drivers for Voodoo 4/5
running Windows XP Professional
If you think you could help me, or just want to pity me a little, go ahead and post something, I appreciate any replies I can get.
Reply 1 of 4, by DRECK
VESA Support with pure DOS
no VESA Support with the DOS-Virtual Machine of WINXP
But the graphic card has a fucking VESA Bios!
I had a similar problem with a KYRO2 card!
my Solution: i installed an older XP Graphic card driver! XP has no Kyro2 driver inclusive 🙁
NO JOKE! Now the DOS BOX works very well with VESA -MODI
Try another XP Driver! NO JOKE!
You have luck! Because WINXP has an Voodoo5 Driver inclusive!
TRY this one first!
YEAH XP has a VOODOO5 DRIVER! In the windows/inf directory is this file: 3dfxvs2k.inf
Deinstall your AmigaMerlin Driver completly
And install the XP Voodoo5 Driver!
Maybe if you have luck 😀
I tested my old Matrox MGA G200 Card!
And WinXP installed the right driver!
Good VESA-Support in the DOS-BOX
Reply 3 of 4, by Snover
Just don't try to Alt+Tab out of NTVDM when it is displaying VESA stuff...heh...
And also, there is an entire rest of the forum that you could have posted this in.
Yes, it’s my fault.
Reply 4 of 4, by psz
One other thing: For your own sanity (IE: Not having it crash randomly), pick up Transport Tycoon Deluxe Windows version if you can find it, and then use Josef Drexler(Aquamaring Dragon)'s patches with it. It'll work in Win2K/XP fine and (if you want them) add a tonne of new features. You can turn said features off, however, and just play vanilla TTDlx.
Patch: http://www.ttdpatch.com/
