Reply 20 of 94, by agent_x007
- Oldbie
myne wrote on 2025-03-14, 09:43:Pretty sure windows deals with different drivers for different cards fine if you manually set it
Yes, BUT only IF said cards use chips from different companies (like Intel/AMD + NV).
In other words :
You can have AMD and NV card at the same time in one PC (even throwing Intel one into the mix SHOULD be fine). However Windows driver stack will drop the ball the moment two Nvidia drivers "see" each other.
NV cards require one driver to support ALL NV cards, otherwise one of them fails to work. You MIGHT be able to get away with super old driver (pre-DX10) to work alongside RTX 50 modern one, but there is no much point in testing that.
