Chinese FX5500 PCI
Reply 20 of 32, by Feanor_twh
Spark wrote on 2025-03-16, 21:19:
In my 810 system, I tried a Radeon 9250 64bit, and a Gforce fx 5200 64bit. This is with a P3 900. Both PCI of course. The Radeo […]
The Radeon 9250 was quite a bit better in my tests.
Later I also got a Radeon 9000 128 bit which is even better, but this is a long card and I doubt it would fit in that small case.
If you are looking for the best to fit into that case, I would go for a 128 bit radeon 9250.
The 9250 should be a great card. The problem is availability and price. The Chinese FX5200 costs around €40. The 9250s I've seen are around €150.
DOS - Amstrad PC1512 NEC V30, 640kb, 128mb CF (XTIDE)
Win3.1 - IBM PS/ValuePoint 486DX2 66, 8mb, Tseng ET4000, 2gb CF
Win98 - AT 386 case K6-III 400, 128mb, Riva TNT2 Pro, 20gb SSD
WinME - Intel Dot Station (Paquito) PIII 750, 256mb, FX5200, 128gb SSD
Reply 21 of 32, by Trashbytes
Feanor_twh wrote on 2025-03-17, 00:56:
I agree. I already have the adapter on the way and a 2.5" SATA SSD waiting to be mounted. The motherboard has a stupid ATA33 lim […]
Trashbytes wrote on 2025-03-15, 11:54:
A SSD would give you an even bigger performance boost, something worth considering since a 2.5" SSD with a SATA to IDE board would produce less heat than the spinning rust factory and be a million times faster.
Yes you would notice it even on a P3 rig, it would feel right snappy and load games a lot faster. Trim support isn't worth worrying about on a retro machine, you wont be using it 24/7 nor will you be filling up the SSD so its on board garbage collection can handle provisioning and empty cells just fine.
I agree. I already have the adapter on the way and a 2.5" SATA SSD waiting to be mounted. The motherboard has a stupid ATA33 limit, but even so the SSD will run more than twice as fast as the HDD.
I've been testing with RivaTuner. I discovered several things:
- The maximum memory speed without artifacts is exactly 346MHz. So I think I'll be fine with 333MHz (166MHz), right?
- There's no noticeable difference between RTCW or Max Payne when changing the GPU and memory settings. Switching between 200-300MHz on the GPU and 200-350MHz on the memory speed results in a difference of 4 or 5 fps
So I'm thinking that the PIII's 100MHz bus or the PC-100 SDRAM is the bottleneck, or the PCI bus, regardless of which GPU I'm going to mount.
Really, both RTCW and Max Payne are playable, the latter even at 1024x768, so I don't think I'm too bad. Being able to play Mafia 1 would be great, but I think I can live without it.
Hmmm that does sound like you are CPU bound there, you are right the 100Mhz bus and PC 100 ram wouldn't be helping but are far less of an issue.
Reply 22 of 32, by emu34b
If you're running Socket 370, maybe consider getting a 133 MHz FSB (EB) Coppermine, plus some PC133 memory. That will up your performance quite a bit. Don't need to get the 1 ghz one, but 866 or so ought to be cheap and a huge boost. If on Slot 1, though, I hear a Tualatin Celeron is a good fit, as long as you really know what you're doing with a slotket adapter...
Also, I would do a bit of a burn in test on that overclock. Make it run something stressful like a benchmark for about 5 - 8 hours. 166 MHz ought to be fine, but maybe back it off to 163 or 160 if you get any, even small glitches. Mine was rock solid at 170 MHz, but results may vary, of course.
Reply 23 of 32, by bertrammatrix
Feanor_twh wrote on 2025-03-15, 10:40:
bertrammatrix wrote on 2025-03-15, 03:38:
What games are you running?
RTCW and Max Payne are the most demanding ones. They run but I can't play at 1024x768, I have to go down to 800x600 if I want to keep high settings on everything else.
That sounds about right, you are actually doing pretty good seeing that is with a PCI video card, I'd have to say I'm impressed. My last P3 was about that mhz on a bx440 with an AGP GF2 Ti and 800x600 in those games was also where it was at. Smoothness in those (and a few of my other favs like mafia or NFSHP2) at 1024x768 didn't come until I migrated to a Via based board with a 1+ ghz p3 on 160mhz fsb and a GF3.
It's unfortunate there were never any intel 810 chipset boards that would allow higher FSB (that I know of), it would be interesting to see how they performed highly overclocked.
In any case, I've been down a similar rabbit hole before- I once had a compaq with a bx440 board that with the help of a slot-t eventually ended up running a 1.4 tualatin. I remember being underwhelmed in the end - it was not at all much faster then the 900mhz p3 it replaced, I suspect the low FSB was the main limitation
Reply 24 of 32, by mockingbird
Even a Pentium 233MMX can max out a 64-bit GeForce FX.
(Decommissioned:)
Reply 25 of 32, by Feanor_twh
emu34b wrote on 2025-03-18, 01:33:
The chipset is limited to 100MHz FSB and PC-100. It was originally 66MHz FSB, and I had to make a hardware modification to get the full 100MHz bus.
So I have a 1000mhz 133FSB PIII, running at 750, 100FSB, wonderfully cool 😉
Maybe I could reach 1ghz with a faster processor, if that would do any good.
Reply 26 of 32, by Feanor_twh
bertrammatrix wrote on 2025-03-18, 14:41:
And so it is. I'm starting to think we can't go any further with the PCI, 100FSB, and PC-100 trio.
But I'm still curious to try that same configuration with an even more powerful GPU, while still being PCI. If I get to do that test I will post the results.
Reply 27 of 32, by emu34b
Feanor_twh wrote on 2025-03-18, 17:34:
I believe the 100 MHz FSB Ghz models (1.0 and 1.1) would be easier to find, due to them being less desirable. Saw an adapter on ebay a few days ago to adapt a Tualatin to older 370 boards if you want to go to 1.4 Ghz (with a celeron).
Reply 28 of 32, by Feanor_twh
I would like to modify the BIOS to return this card to its original FX5200 state. Does anyone know how to do this?
It's not really necessary, but I think be nice if the card BIOS didn't trick the system for think it is a 5500, only for trick the drivers to think again it's a 5200.
I know the drivers can be modified, but if I were to use the Omega drivers, for example, this would be more difficult since I haven't been able to unpack them yet.
Reply 29 of 32, by analog_programmer
Feanor_twh wrote on 2025-03-24, 21:12:
Dump the card's BIOS. Get "X-BIOS Editor" and try to change device ID in your videocard's BIOS file to the one for the FX 5200 cards - I think "0322" should work. Flash the card with this new modified BIOS.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 30 of 32, by Feanor_twh
I did it, I modified the device ID and even the initial boot message "NVIDIA GeForce FX 5200 VGA BIOS," and I flashed it. Everything seemed fine, but AIDA32 still shows an Nvidia FX5500 GPU.
Why could this be? I didn't want to reinstall the driver to see if Win98 would finally detect it as an FX5200, just to avoid further complications.
Reply 31 of 32, by dm-
there is 2 options to change device id:
1. device id is a strap resistor. i don't think you can find it on the board.
2. flashing software straps to the bios. required advanced knowledge. read the "Quforce" topic.
Reply 32 of 32, by Feanor_twh
Thanks for the information. I've read the QuForce thread and I understand the situation. I now feel lucky that my card is producing video signal after only modifying the ID in the BIOS.
If I'm up for it, I'll try modifying the strips thing, but it seems complicated.
