First post, by pappyN4
It looks like AMD has announced that RDNA4 (RX 9000 series) will need Class 3 UEFI to work.
Intel already enforced Class 3 starting with their 11th gen iGPUs.
Does anyone know what generation of NVIDIA GPUs forces class 3 or does it still work with class 2 (UEFI with CSM enabled)? I cant seem to find anything concrete online.
Related question. Would a class 3 card work if you were able to boot into windows with a different card?
So for example, motherboard has UEFI/w CSM enabled. A GT700 series in the second GPU slot set as primary boot in the motherboard and boots into windows. Would the class 3 GPU in the primary slot be visible, able to install drivers for it, disable the second card in windows, and the next time you reboot the computer will POST using the secondary card and then switch to primary once it boots into windows?
Something along the lines of a dual boot situation where the second card would already be used for an older version of windows, but use a newer primary card with modern windows.
98/XP/XP64, ASUS A8V Deluxe, A64 3200 Venice [67W], 2GB DDR400, Ti4200 128MB [35W], M4 128GB SSD w/SATA-PATA
XP/XP64, GA-F2A68HM-HD2, A8-7600 [45W], 16GB DDR3-2133, Zotac GTX750 1GB passive [55W], 2TB SSD
