Jones817 wrote on 2025-03-18, 13:57:
Thanks for this, I am going to give this a try,
Also, one more question, if you have a mobo that is not showing video but everything else is working, does that mean that it’s DOA?
Not necessarily, it all depends of the situation, For e.g. in my case, when I was building my Win98 pc I tought that my Asus P4i65g was DOA when i got it from ebay, because it did not wanted to turn on at all, I changed ram, changed cpu, changed psu, I also try to turn it on with and without the gpu but still nothing. Later I found out that because I did not fit it correctly inside the case one of the mobo stands were making contact with the mobo itself so it refused to turn on. After fixing that minor detail everything was running just fine.
Anyway if a mobo you have does not turn on does not mean its dead, just try to turn it on outside the case like in a free antistatic place and play around with it to see the problem, like switch cpu, switch the ram, the gpu, psu , even try that on a mobo you know its working to kind of see potential errors that are preventing your mobo to post. Just considered DOA after you did almost every troubleshoot it on it.
