Reply 40 of 68, by feipoa
- l33t++
Minor update:
I let my kids play Duke3D with the testbed system: 85 MHz SXL2 and AHA-1542CP. After 15 minutes, I hear some B&M ("bitch and moan"). Duke3D is hung with some DOS error layered over the game graphics, stating DOS cannot write to the HDD or something of this nature. When I inquired, I was told it was the 3rd time he tried to save the game progress which then hung the system. The first two saves were successful. This was with the Alpha1 interposer and the MEMW# wire connected.
I fiddled with some cyrix.exe settings, but the same problem occurred. I swapped the CPU for the Evergreen SXL2 and ran again. Same problem. Upped the voltage on the Evergreen, still hung after the same time period. I swapped the AHA-1542CP in favour of the AHA-1522B, and the kids played for 2 hours without incident.
It is probably best to just stick with the AHA-152xB in 386 systems containing an SXL2. Some systems might run OK with the AHA-1542CP, but resolving these intermittent issues can be time consuming and frustrating.
I have my AMI Mark V Baby Screamer setup with the AHA-1540CP running at only 66 MHz and my kids haven't run into this issue. On the testbed, I suppose should have tried taking the DRAM speed down from 1 ws to 2 ws. Maybe with the AHA-1542CP it needs the extra time at 85 MHz?
