OS uptime faker
First post, by mitradis
i found some information about stuttering in some old games. I couldn't understand for a long time why if the PC is on for a long time, then when I enter Blitzkrieg I get stutters.
About the major stuttering issue, the one the OP solved by uninstalling GeForce Experience and rebooting. (As opposed to Jocek's minor stuttering, which sounds like a different issue.) I ran into this same problem just now, but I didn't have GFE installed to begin with. But seeing this thread reminded me of another game with a similar issue: Neverwinter Nights 2 has hideous stutter when scrolling if your computer was last booted more than ~1 day ago. That's because it uses a global Windows timer for some graphics tasks, but it can't deal with timer values that are too high. I suspect Blitzkreig has more or less the same issue: simply rebooting solved the stuttering for me.
https://steamcommunity.com/app/313480/discuss … 16640399301556/
Any one knows how reset this timer without windows restart?
Reply 1 of 9, by Squall Leonhart
mitradis wrote on 2025-03-18, 12:40:
i found some information about stuttering in some old games. I couldn't understand for a long time why if the PC is on for a lo […]
https://community.pcgamingwiki.com/files/file … ire-stutter-fix - patches buggy d3d9 games.
Reply 2 of 9, by mitradis
Squall Leonhart ty for answer. But this will not allow to put dgvoodoo. Dege can you add this feature?
Reply 3 of 9, by BEEN_Nath_58
mitradis wrote on 2025-03-19, 19:33:
I think this is the famous uptime bug, as they instructed, restarting the PC should fix the problem. I generally don't see it as a dgVoodoo2 related thing.
Reply 4 of 9, by Squall Leonhart
BEEN_Nath_58 wrote on 2025-03-20, 02:44:
The uptime bug is just QueryPerformanceCounter returning large numbers,
the dll fix just fakes the current QPC time, this should do similar
https://github.com/CookiePLMonster/UptimeFaker/releases
unpack the attached into the game folder, if it doesn't load the winmm.dll, try any until you find one that works.
The attachment UptimeFaker.zip is no longer available
Requires VS2015-2022 redist x86
It would be ideal for DgVoodoo to implement it too, to minimize the amount of dll's doing things in the game process.
Reply 5 of 9, by Dege
The thing is, that I cannot "just implement" everything that's not related to the dgVoodoo graphics dll's. There are things, like the mouse, or GDI in general that can be hooked along the way (more or less), when dgVoodoo rendering is active, but not everything. Querying the OS uptime is completely independent API on Glide and DX, and hooking it right at the process startup is a must (see UptimeFaker you linked). Otherwise the application could get inconsistent time data. For example, it can query it once before even initializing rendering, to have a "start" point, and then do it frequently during rendering, when dgVoodoo returns the altered data.
The only way for these type of hooks would be distributing a winmm.dll in the dgVoodoo package. Btw, I have such a dll but it didn't work with a game I tested it with, so I did not bother with that any further. 😁
Reply 6 of 9, by mitradis
The plugin in doesn't work with Blitzkrieg or just doesn't work.
Reply 8 of 9, by ELK
I think these fixes may be related but I'm not 100% sure. You could give them a shot though.
Try switching to old timers (this has solved issues in plenty of old games for me)
https://sites.google.com/view/melodystweaks/m … rs-hpet-tsc-pmt
PMT + RTC: bcdedit /set useplatformclock Yes - bcdedit /set useplatformtick Yes - make sure HPET is disabled in BIOS
***to revert back to default***
TSC + TSC without desync: bcdedit /deletevalue useplatformclock - bcdedit /deletevalue useplatformtick - make sure HPET is enabled in BIOS
And the second thing you could try is disabling the performance counters themself. At least I think that's what this does 🤣. Idk if having no clock will break the game.
make a file named Disable_PCW.reg with this inside
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\pcw]
"Start"=dword:00000004
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\taskmgr.exe]
"Debugger"="C:\\procexp64.exe"
to turn them back on make this .bat file instead of .reg Enable_PCW.bat
@echo off
cls
setlocal enabledelayedexpansion
IF EXIST "C:\Windows\system32\adminrightstest" (
rmdir C:\Windows\system32\adminrightstest > nul
mkdir C:\Windows\system32\adminrightstest > nul
if %errorlevel% neq 0 (
powershell "Start-Process \"%~nx0\" -Verb RunAs"
if !errorlevel! neq 0 (
powershell "Start-Process '%~nx0' -Verb RunAs"
echo You should run this script as Admin in order to allow system changes
echo The tweaker will now exit
pause
exit
exit
reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\taskmgr.exe" /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\pcw" /v "Start" /t REG_DWORD /d "0" /f
echo Done, reboot
pause
Reply 9 of 9, by Squall Leonhart
no to all of your post;
