Reply 56380 of 57996, by dominusprog
Major Jackyl wrote on 2025-03-17, 02:13:
Got some stuff today. The most interesting though, is these screens and video cards/interface cards. […]
The attachment 20250316_210319.jpg is no longer available
The attachment 20250316_205055.jpg is no longer available
The attachment 20250316_210348.jpg is no longer available
From some kind of "industrial" PC, like a casino game? Very interesting video card. It uses the SCSI output to the monitor input. Luckily the box had three screens and three cards. I tested the first one and it has video output! Pretty neat! Hope it can run DOOM, 🤣 It can barely run the BIOS, 🤣
Build a wooden case for it. You can make a frame out of aluminum profile.
Reply 56381 of 57996, by BitWrangler
dominusprog wrote on 2025-03-19, 15:16:
Now they make some interior household trim out of extruded plastic, it's less likely to split up to drive screws into it, it will hold a self tap metal screw pretty well if drilled. So you can get inside angle or outside angle offcuts of that and use it to hold lighter/smaller panels together. Wouldn't use it for more than say 1/4" ply though.
Reply 56382 of 57996, by Major Jackyl
BitWrangler wrote on 2025-03-19, 16:24:
I would like to make a tri-angle computer with the motherboard standing in the middle, but I don't know if they can all work simultaneously... If no, I'll knock a hole in a scrap case, see how it looks mounted inside a computer. Good for emergency DOS only.
I only have one cable at the moment; I want to see what happens if I plug all three in at once. Is there a ribbon that can do all three with one card?! I had two cards in my test computer and it didn't mind, but I couldn't connect more than one at a time (all work). Windows knows nothing about it. Doesn't even know where the video is coming/going. Duke3d was a sledge-fest (slow'd down Duke is pretty metal, too) and Doom runs... playable. (In DOS)
(https://youtu.be/PdtfbcWLJ6Y) - Short video of slow'd down duke3d. Mostly the sound.
The attachment 20250318_182902.jpg is no longer available
The attachment 20250318_184124.jpg is no longer available
The attachment 20250318_184200.jpg is no longer available
I still haven't found much on the cards. Nothing on the screens, either. They DO pass the 70hz test, though and look pretty good. I'll look up chips on the WDFPCard soon, see if I can't find some drivers/init program or something. The monitors, cards AND the box they came in all said "Computer Dynamics - The Flat Panel Experts™"
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 56383 of 57996, by dominusprog
Major Jackyl wrote on 2025-03-19, 22:38:
I would like to make a tri-angle computer with the motherboard standing in the middle, but I don't know if they can all work sim […]
Setting the video output in duke3d.cfg to Screen Buffer can improve the performance.
Reply 56384 of 57996, by Nexxen
2x1GB DDR 333
1st time I see 333MHz 1GB modules.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 56385 of 57996, by sfryers
Ahrle wrote on 2025-03-14, 18:08:
#2. Compaq Contura 430CX […]
Not sure about CPU (can't get into BIOS), but has 8MB RAM, and a relatively huge 700MB HDD with catchy noises.
Obliterates the Acernote's performance in the pinball demo that came on both.
Can't find anything wrong except dead CMOS battery, and previous owner's notice it won't cooperate with SD cards.
I had one of those in the late 1990s. Mine was a 486DX2-50; model no. 410C if I remember correctly. Sadly it got stolen when I was at University 🙁
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 56386 of 57996, by Ozzuneoj
Okay, here's another one for the PC hardware detectives out there.
Bought this computer as-is recently, and 80% of my reason for purchasing it was a component in this photo. Can you spot it?
The attachment mysterypc.jpg is no longer available
EDIT: To keep it fair, here is the other picture I used to identify the part:
The attachment mysterypc2.jpg is no longer available
And yes, I know the PSU has some surface rust. I will not be using that. The case is super cool though and thankfully isn't rusty. I'm not sure if this is an original GEM desktop or if all of the parts were swapped out at some point (it has an 8x CDROM too).
Reply 56389 of 57996, by TheMobRules
Ozzuneoj wrote on 2025-03-21, 02:55:
And what sound card is it? 😁
When I saw those pictures it jumped out at me, because only one card looks like that. It's a fairly rare card but not total unobtainium.
The voltage regulators in that position make me think of PAS, but the rest doesn't match with the images I can find...
Reply 56390 of 57996, by slivercr
Indulged a bit yesterday and bought a funky motherboard to test CPUs with
The attachment s-l1600.webp is no longer available
I wasn't too sure, but intel branding, ISA, and 3 RAM slots suggest it's a 440BX so I pulled the trigger. Looks to be this motherboard.
From the same seller I got a Radeon DDR, the AIW version–I was missing an og Radeon in my collection so this is quite welcome!
The attachment s-l1600 (1).webp is no longer available
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 56391 of 57996, by Kahenraz
slivercr wrote on 2025-03-21, 05:16:
That's kind of odd. The website you linked doesn't mention Coppermine support, even though it's a 440BX. Something worth checking out and letting us know if it's supported.
Reply 56392 of 57996, by Ozzuneoj
Kahenraz wrote on 2025-03-21, 05:47:
The voltage regulator should support the lower Coppermine voltages, so it's just a matter of whether the BIOS does or not.
Reply 56393 of 57996, by Xicor
Ozzuneoj wrote on 2025-03-21, 00:43:
Okay, here's another one for the PC hardware detectives out there. […]
I spy with my little eye .... A Pro Audio Spectrum Plus !!!!
Reply 56394 of 57996, by Ozzuneoj
Xicor wrote on 2025-03-21, 20:35:
You got it! I think I've only ever seen these come up for sale 4-5 times in the years I've been collecting sound cards. I have one that I was never able to get working fully. Now I have a second that will hopefully work and will maybe even aide me in fixing the other one.
Oh, and here's your trophy. 🏆😁
Reply 56395 of 57996, by Xanxi
Unsure that it is truly retro, but i just got a Ketron SD2 for my MIDI stack.
I can't test it yet because i lack a free wall plug and need adapters to add it to the stack, probably by daisy chaining it to another device and using a secondary input on my mixer.
Reply 56396 of 57996, by pan069
The Sunshine PSU? 😆
Reply 56397 of 57996, by cyclone3d
Ozzuneoj wrote on 2025-03-21, 21:07:
Oh yeah, now I recognize it. I actually have one as well.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 56398 of 57996, by Horun
Nice find ! Yes a bit rare. The other fairly rare MV's are the original PAS 8bit and the Sigma Designs PAS16 (53-000296 AKA 650-0053-029) with both SCSI and Sony cdrom interfaces (have not seen one for sale in years until just recently).
Reply 56399 of 57996, by Ozzuneoj
Horun wrote on 2025-03-22, 02:24:
Yeah, an original PAS 8bit has managed to elude me all these years. They have popped up a couple times for cheap but they're always snatched up before I can grab them.
