Reply 29420 of 30568, by PD2JK
It took a lot of swapping them 1.44 MB disks, but now we're getting somewhere. Next step is to create a RAID5 array, or else the i960 will be poking its nose.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 29421 of 30568, by PcBytes
Fixed my cheapo ESS 1869F card's clipping issue by removing the TEA2025 amp entirely, then connecting a few pins together (pin 2 to 7, pin 15 to 10, pin 3 to 14, and 6 to 11. In order, they are OUT2 to IN2, OUT1 to IN1, BOOT2 to BOOT1, and the last two are both called FEED for feedback, they had to be tied both together as well.)
Will probably keep it aside as emergency card and purchase a more complete 1868/1869F (component wise, not chipset wise.) to use.
Reply 29422 of 30568, by dominusprog
StriderTR wrote on 2025-03-20, 21:49:
dominusprog wrote on 2025-03-20, 21:42:
StriderTR wrote on 2025-03-20, 17:39:
My "new" Windows 98 build finally has a proper home. I got it all crammed inside a nice tiny case the best I could. I really wa […]
My "new" Windows 98 build finally has a proper home. I got it all crammed inside a nice tiny case the best I could. I really wanted to keep this build as small as possible to fit into my limited use space. Sure, I have room to store things, but I like to use what I build, so keeping this build small enough to fit where I needed it was a must.
I mounted the internal SD/IDE in a 3.5 tray to keep it secured to the inside front of the case, while the external SD/IDE I mounted to an open expansion slot with a simple adapter I printed so I could easily swap out files as needed.
I also added an extra fan blowing right over the chipset heatsink to help keep things cooler becasue the Athlon 3000+ and that chipset get warm. It's a quick and dirty mount, but it works, and it keeps it all a lot cooler.
Now I just need to wait on the stickers I ordered from Geekenspiel to arrive so I can dress up the outside of the case a bit. 😀
Overall, this build it working out really well. It fits in the space it's needed and it's performing wonderfully so far.
Case: https://www.amazon.com/dp/B0CHPRKW18?
So, why not use a smaller (50x50mm) fan for the chipset? A smaller fan will cover all the fins, hence it'll do a better job cooling the chipset.
The one 50x50 I had in my "fans box" was on its last leg. Sounded like a mini rock tumbler when I fired it up. So, I just used what I had on hand.
It works good. Keeps that whole area of the board cooler. I mean, the fans not even necessary, I just prefer to keep this older hardware as cool as possible. If I ever get my hands on proper sized fan, I'll switch it out, but for now it works so I'm not all that worried about it. 😀
True that in this case the fan is not necessary but keeping these old parts cool is a good idea 🙂.
Reply 29423 of 30568, by PcBytes
Another win. Finally got my 3C905B-TX rid of that "TriROM" boot interface that showed up no matter what mobo it was in.
Had to desolder the EEPROM. Might add a socket later down the road but thank god it went away, it was annoying to wait for it to exit TriROM.
Reply 29424 of 30568, by Nexxen
Tested the 2 x 1GB DDR 333MHz sticks.
One is fine and passes 100%, the other one gives hundred of thousands of mistakes.
I can't really understand if it is some incompatibility, but I don't know what other test I could use to check if it is not.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 29425 of 30568, by Trashbytes
Nexxen wrote on 2025-03-22, 00:36:
Memtest86 is likely the best, if they are both the same sticks then I doubt it'll be an incompatibility if one works and the other doesn't.
Reply 29426 of 30568, by StriderTR
H3nrik V! wrote on 2025-03-21, 05:37:
StriderTR wrote on 2025-03-21, 00:38:
I was thinking about doing that. Currently using SD cards, one for the system, one for ISOs etc. […]
H3nrik V! wrote on 2025-03-20, 23:09:
Migrating my W98 disk setup to one ssd having both a Win98SE partition, an ISOs partition, a drivers partition and a partition with Win98SE install files and script for unattended install.
Holy smoke a reinstall is snappy now 😁
What adapter you using? I've got the one linked below, and it works, but It seems to be picky what drives you use with it.
https://www.amazon.com/dp/B09GVDK2H1?
https://www.startech.com/en-dk/hdd/ide2sat2
I read many places that the StarTech ide2sat2 was indeed highly compatible, and it works fine with my Hynix 128 gig drive - haven't tried other drives, though. But I think I'm gonna buy some more of them and maybe keep the ISO part as a separate disk I can use in all rigs, as separate rather than a partition ...
Thanks!
I found them for sale over on Amazon and just picked one up. If I had seen it sooner I would have purchased the StarTech one over the one I got. I've always had good luck with StarTech products. 😀
https://www.amazon.com/StarTech-com-Drive-Opt … /dp/B00EOJNGC2/
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 29427 of 30568, by Trashbytes
Have spent the arvo digging out and cleaning my C64, its been a hot minute since I last used her and while the box stopped a lot of the dust it still needed a good clean. I also wanted to check internally to make sure nothing had .. expired while in storage.
Thankfully she is still kicking !
Now I get to spend the next few days checking disks, tapes and carts to see if any have bit the dust, going to start backing them up. Im not 100% what a good way of backing the tapes up would be or if I even have the setup to do so, going to be a fun journey digging into that topic.
Now that i think about it it might be easier to do a bit of sailing and see if I cant find some booty that matches what I own rather than subjecting Disks and Tapes to even more abuse.
Reply 29428 of 30568, by Nexxen
Trashbytes wrote on 2025-03-22, 01:10:
I needed to hear that to dissipate my doubts.
Also, the mem chips look like they are piggybacked. Strange sandwich.
Edit: https://www.datasheets.com/part-details/k4h51 … ronics-26687961
Stacking is a technology developed by samsung, so it is what it is I guess 😀
Reply 29429 of 30568, by I_Eat_Boogers
Got an old Star LC-10 Dot Matrix Printer, originally bought for the Amiga, up and running on Windows 10.
Had to tell Windows not to verify the driver, else the driver installation would not go any further. This was done by giving the following commands in Command Prompt (Admin):
bcdedit.exe -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING ON
Restarted the computer
Mounted the dollar item USB -> Parallel Port cable that I got from eBay. Thinking they are all good, just got the cheapest that was available.
Windows 10 came out and said, unknown device.
Through Device Manager, right clicked on update driver for that Unknown Device
In the Update Driver dialog, selected the option to "Browse my computer for drivers"
Next, selected "Let me pick from a list of available drivers on my computer"
Next, selected "IEEE 1284.4 compatible printer," and clicked "Next"
Clicked on "Have Disk."
The little CD-ROM that the cable came with, grabbed the latest driver from there, in this case the 64-bit version is what matched this system.
Followed the prompts and once again, restarted the computer
Installed the Generic Dot Matrix printer driver in Windows and in this case, selected LPT2 as the port. (You can right click in Device Manager on the Parallel port part and see what port it has assigned for you)
Can this mess up your system, a little bit, everything is a gamble. It worked for me.
Cheers
Reply 29430 of 30568, by Nexxen
I_Eat_Boogers wrote on 2025-03-22, 09:22:
Got an old Star LC-10 Dot Matrix Printer, originally bought for the Amiga, up and running on Windows 10. […]
Installed the Generic Dot Matrix printer driver in Windows and in this case, selected LPT2 as t10he port. (You can right click in Device Manager on the Parallel port part and see what port it has assigned for you)
Cheers
This is interesting, I have one and need to repair it.
Good to know W10 can work with it.
Reply 29431 of 30568, by Trashbytes
Nexxen wrote on 2025-03-22, 09:10:
What in hell .. why would they do that, unless they tried doing that to repair that stick. I doubt it did much.
Reply 29432 of 30568, by Nexxen
Trashbytes wrote on 2025-03-22, 10:40:
Both sticks are like that.
This is really beyond my knowledge. Let's say one solder joint is off. Good luck finding it. 🤣
Gonna send it back, it's purposeless to me now.
Reply 29433 of 30568, by leecw16
Today I listened to my first gen IPod Touch. Later I’m gonna load up Windows 95 and carry on writing a book I’ve been working on. Love that startup sound.
Reply 29434 of 30568, by PcBytes
And the 3com card is done. Now it has an DIP32 socket, much like the non-MBA version of it (3C905B-TX, which is basically what it got turned into.)
Reply 29435 of 30568, by henk717
Finally made a video overview of my retro PC, but feels a shame if I just posted it since I want to write a proper thread post for it detailing all the optimal stuff.
At least the video for that post is made now, now I just need a writeup.
Reply 29436 of 30568, by kingcake
Here's a new one for me. Flashed a Packard Bell /w the Intel Advanced/HL mobo with a MRBIOS upgrade to get IDT Winchip support. Now the KB and Mouse PS/2 ports are swapped!
What is clearly marked as the mouse port on the case only works with the KB plugged in. Same with mouse.
I mean, I'm sure it's possible to init the KBC and tell it which port is which, but in all my 30 years of upgrading BIOS images I have never seen that.
Reply 29437 of 30568, by Trashbytes
kingcake wrote on 2025-03-23, 02:33:
Well at least they both still work .. could have been worse 🤣
Reply 29438 of 30568, by kingcake
Trashbytes wrote on 2025-03-23, 04:39:
At first I thought the BIOS was obviously for the wrong chipset/kbc. I almost reverted back to the OEM bios. Then I happened to turn it on without the keyboard plugged in and it suddenly said "no mouse detected". Which gave me the idea to swap the KB and mouse around. Weird.
Reply 29439 of 30568, by oh2ftu
Built one machine again.
The case is what I had in my youth. Unidentified ATX-case that clearly has AT-history. Detachable motherboard-plate, power button is similar (but off-(on) as a AT-switch).
BF6 motherboard (I had a BE6-II in the same case) - close enough.
For CPU I did my dream, 1GHz P3 (albeit 133MHz FSB) on a Soltek slotket - as I also had. For CPU I ran a Cel466, then some Cel677 or 733 iirc back in the day.
I think I have a Golden orb somewhere, might swap that here as well 😀
RAM 2x256MB, clearly more than I had.
GPU GF2ti. Much better than I had (Viper 770 iirc).
3com NIC.
Soundcard is still undecided. I did run a SB128pci, but I won't be doing that. Maybe a SB16vibra or SBlive.
Storage SSD + ide2sat2.
Guess the case will stay "stock" - unlike the one I had; painted black, blue hdd/floppy/optical leds, crudely hacked window etc 😁
