First post, by Dimos
Greetings to all! A couple of days ago i finally installed an Ssd drive on my Windows XP build. Knowing of course that from Windows Vista and before no Microsoft OS natively supports the Trim command for Ssd drives i have spent quite some time searching for some kind of software that could manually Trim an Sdd drive. Of course modern Ssds work so well that even without Trim you could use one on an old Os and don't have to worry about performance reduction or premature wear (Garbage Collection works at the firmware level, independently from the OS, Trim just makes this procedure easier, more efficient). After several hours searching various forums, including Vogons, i have found a couple of software utilities that had a manual Trim option. I installed and tested three of them (Anvil's Storage Utilities, Iobit Smart Defrag and Elpamsoft Ssd Tweaker) but none of them provided any kind of documentation concerning the Trim option (if it works only for OSes that natively support Trim and the only thing they do is manually sending the command or they somehow work on older OSes and in which way do they do that exactly) and i was uncertain if they did anything really for Windows XP. Until yesterday i came across some info that suggested that Acronis True Image 2014 also has an option that enables Trim and the person mentioning that also verified that it was indeed working on XP after using Trimcheck. So intrigued by this i searched a little further and came across this document: https://dl.acronis.com/u/pdf/ATIH2014_userguide_en-US.pdf
In this it is mentioned that:
Note: The utility uses the standard TRIM command to inform an SSD about blocks of data that are no longer in
use and can be erased. Please make sure that your SSD has necessary firmware to support it.
and also:
Trimming an SSD by means of Acronis True Image 2014 is reasonable only if you use Windows Vista or earlier. Windows 7 supports […]
or earlier. Windows 7 supports the standard TRIM command right out of the box and erases cells as
soon as data is deleted.
To trim an SSD:
1. On the sidebar or on the toolbar, click Tools & Utilities and select Trim SSD.
This opens the wizard.
2. From the list of available drives, select the SSD(s) that you want to trim and click Next.
3. Review the summary page and click Proceed.
4. If you have run the wizard under Windows, click Reboot when prompted.
After the reboot, the operation will automatically proceed in the standalone Linux-based
environment. When the operation is complete, the wizard will boot up Windows again.
So it explicitly says that what it does is to send the standard Trim command and that this function actually is provided in order to be used with older OSes that don't natively support Trim. So as you can imagine i installed the specific version (2014) of the software (newer versions seem to lack the Trim option, haven't verified that myself), found the Trim option, selected my drive and everything went as expected, the pc restarted, it entered into the linux based boot environment, Trim completed and computer restarted again. To be absolutely certain that it worked i run Trimcheck (very useful tool btw): https://files.thecybershadow.net/trimcheck/ before and after the procedure and verified that Trim actually works! So that's it, there is at least one completely verified third party tool that actually does this job and thought that it would be useful to share this with anybody that might be interested!
Cpu: Intel i7 4790k
Gpu: Gigabyte Xtreme Gaming 980 ti
Ram: G-Skill Trident X F3-2400C10Q-16GTD
Mobo: Gigabyte Z97x Gaming 5
Hdd: T-Force Vulcan Z 512 gb Ssd
Psu: Corsair CX650
Soundcard: Creative SB Audigy RX
Os: Windows XP Sp3 x86
