First post, by kotel
- Oldbie
Recently I finally started swapping the core from my "working" FX 5500 with artifacts and probably bad Vref rail (this one caused boards to go drunk) onto another FX 5500 with an shorted core after a reflow.
After desoldering both of them (and making sure none of the power rails are shorted to GND before that) I am now stuck at choosing the correct ball size.
Pitch looks to be 1mm and ball size seems to be 0.54mm on average after desoldering. Ball count per side is 30. From this info I should choose an 30x30 stencil with 1mm spacing and 0.55mm ball holes right? If so, this stencil pack should have the correct stencil, right?
You say you've got me outnumbered
I say you've evened the odds
You doubt the strength I hold within
Just one bounce back is all I need to win!
