Reply 1340 of 1875, by uniQ
- Newbie
Shreddoc wrote on 2025-03-25, 22:25:uniQ wrote on 2025-03-25, 14:23:I just installed my brand new PicoGUS 2.0 together with the WP32 McCake Wavetable board and it's simply amazing under DOS. The o […]
The only problem so far is to get this setup working with SB2.0 Emulation under Windows 3.11.
I tried SB1.5 and SB2.0 (old and new) drivers but as soon as I start a MIDI playback, the system just freezes.Windows sounds work fine with the SB1.5 driver but also crashes the system when I use SB2.0 drivers.
Anyone else or am I doing something wrong?
The short answer is that PicoGUS has been developed to work with DOS software.
Windows compatibility for PicoGUS's different modes varies, and that is entirely to be expected.
I thought so, thanks for the clarification.
But maybe someone here in the forums has successfully installed the PGUS in SB mode on Windows 3.11.
