Reply 20 of 23, by momaka
ediflorianUS wrote on 2025-03-17, 13:31:
I am sorry to pull up this topic , but I want confirm Similar Issue on (my) old ECS K7SOM+ 5.x /5.2 ...-forgot the version 11/19/2002
* After changeing my low PC2100 ddr to a SDR Kingsone 133Mhz module , system with a Socket Duron 1200 in it , powered/booted/posted up. (before that I got black screen of death) - I almost started a recap for no reason (caps seeme fine I checked them visually).
Nothing to be sorry about. If anything, thank you for adding more information / further confirmation that this is an actual issue.
FWIW, I haven't pulled mine out of storage yet to try and play with it to see if this issue can be remedied by a newer BIOS.
Thank you. (so keep in mind the ECS stuff with DDR+SDR , with a duron , test with SDR first ,I am not even sure if a duron suports DDR, could not find refrence on CPU-world).
Socket A / 462 CPUs don't have the memory controller onboard like the next gen AMD did (socket 754/939 and onwards.) Therefore, the type of memory that can be supported by the motherboard is completely down to the chipset - particularly the Northbridge, as this is where the memory controller resides, thus being the link between CPU and RAM.
Looking at pictures of your specific board (v5.2 and not v7.x, which is a completely different animal with DDR slots only), I don't see any jumpers to have to put on / remove for selecting between DDR and SDRAM... so all of that appears to be done automatically at the time of BIOS POST.
As such, this is why I think an updated BIOS might solve the issue here.
Before recommending that, though, I really need to try that on my board first.
- IF anyone knows exactly wtich cap I need to change , (for no issues in the future) , just let me know - I don't want to change all the caps if they are not bulged and system P.O.S.T.'s.
Probably the caps for the CPU VRM first, as that's the only buck-regulated rail on these ECS boards, it seems (and thus the rail to stress caps the most.) That would be the caps between CPU socket and rear I/O port area.
Looking at pictures particularly for the K7SOM+ v5.2 (as v7.x appears to be quite a different board), I don't see any other buck-regulated rails, so only the caps mentioned above would be the most critical to change. Of course, if you do have the caps, maybe change the ones around the RAM slots and Northbridge too... though that pretty much most of the caps on this board. 🤣
In terms of what's more likely to fail: the green G-Luxon caps are definitely more likely to fail and tend to be more unstable over time, IME. If you have these on the CPU VRM, definitely replace them. On the other hand, if you have purple OST RLX, those seem to do relatively OK on these older ECS boards (but on newer ECS boards from the socket 939/AM2/AM3 era - replace on sight!... especially anything in 8 mm diameter.)
kotel wrote on 2025-03-17, 16:24:
But this aside how exactly did the black screen of death appear? Like after what amount of time, what were you doing with it etc.
Well, for my K7S5A, I have to do exactly nothing - the board simply just does not POST with DDR RAM installed.
It's been a while since I tested it, but from what I remember, I was getting POST codes on my POST card with DDR RAM installed. It would just hang at POST code D-something (IIRC) and that was that.
Reply 21 of 23, by Major Jackyl
I use this board regularly and it did have random no-POST (after restart/power-on) while I was first testing it (enough power cycles would boot it). The juices were leaking out the tops of the CPU VRM caps after I got Windows 98 installed (and I ran 3dmark99, successfully). It hasn't had any issues since re-capping (unless you count my PCI IDE failing)
I love sharing the pile. That board uses a LOT of caps...
The attachment 20241110_140320.jpg is no longer available
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 22 of 23, by kotel
I had been just reminded about my first msi 845pe which didn't work, then worked for a tad bit and then died. The whole story is just too complicated to say so I summarized it in one word.
That might have to do with the chipset since it doesn't get any warm.
Maybe here the VRM or whatever ecs used here for the NB/SB got screwed and there's no voltage going to it? Also if the board does come out of reset check if the CPU VRM is generating proper voltages.
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
Reply 23 of 23, by ediflorianUS
Hmmmm, this seems like a similar case to the EP8K3A+ boards. IIRC in them it was the DDR slots frying themselves and damaging ot […]
I am sorry to pull up this topic , but I want confirm Similar Issue on (my) old ECS K7SOM+ 5.x /5.2 ...-forgot the version 11/19 […]
momaka wrote on 2024-05-02, 13:03:
I also have a K7S5A motherboard, though I never really did anything with it (was a freebie from a PC repair shop about to throw […]
I also have a K7S5A motherboard, though I never really did anything with it (was a freebie from a PC repair shop about to throw it away), other than finally figuring out how to make it POST several years ago. In my case, the board would NOT POST with any DDR(1) RAM of any kind. I tried high density & low density modules of various capacities, and result was the same - none of them got the board to POST. Finally, I decided to try some SDRAM. Miraculously, the board appeared to work fine with that. Thought it must be a fluke incident, so tried with the DDR RAM again, but same thing - no POST. Interestingly enough, I initially thought the CPU I used was the problem, since it was a Duron Applebred 1400 (Thoroughbred B) core and perhaps too new for the board. But that wasn't the case - with the SDRAM, the motherboard booted fine with the CPU.
Unfortunately, I never did anything more with the board since then. I did check absolutely all of the small SMD components on the board to make sure nothing is out of the ordinary... and it wasn't - no chipped resistors or caps to cause the issue that I was seeing with the DDR RAM.
From what I've read online, some of these board can be extremely buggy with their original BIOS. If you have the means to program the BIOS externally to a newer version, perhaps that might resolve your issue?? Or not, IDK.
As for the caps: yes, you should change all of them. I see OST RLP series and G-Luxon LZ. The latter are pretty terrible... though sometime they are still OK, like they are on my board (not that I would leave them on there when I do get to making a build with that board.)
The bulging cap on the top of your board may or may not be the cause of your issues... though I suspect that it isn't, since that cap is on the 5V rail before the CPU VRM high side caps (separated by an inductor, so HF noise from CPU VRM shouldn't be making it back to the rest of the board.)
Aniway the bioses for SiS 740 chipset's are wonkey it seems. (will edit/post a photo at a l8ter date).
IIRC in them it was the DDR slots frying themselves and damaging other stuff, which included the SIO chip.
Over time... The system (mine) was abandoned in garage(was dad's Travel agency PC in early 2000s.... I constantly mantained it back then) , had no ram ( and diffrent cpu , I don't remember what was the original AMD in there back then). I put a Duron, Bios is finekey with DURON+DDR. (it likes SDR) , windows xp runs fine. (with a Seagate 40 gb drive in there +2x128 PC133 SDR DIMMS) , I did not test it more than 2 days of lite load and (IDE 40gb) backup duty to usb drive.
My 80486-S i66 Project
