Some help with setting up SHSUCDX correctly
Reply 20 of 33, by LSS10999
DustyShinigami wrote on 2025-02-13, 01:30:
Because I figured that’s supposed to be the default CD drive letter, no? By default, everyone refers to it and types in ‘D’. My physical CD drive is F. I primarily use my emulated drive in Windows, which is E. And I usually set the physical drive in DOS to be E as well. It can’t be D as that’s my second HDD.
Reminded me of the old days with MSCDEX when I also thought /D means D:. 🤣
I was very little at that time and my knowledge was very limited back then.
Anyway, the manual has detailed explanations about all the arguments the TSRs could recognize.
Reply 21 of 33, by DustyShinigami
LSS10999 wrote on 2025-02-13, 02:55:
Reminded me of the old days with MSCDEX when I also thought /D means D:. lol […]
Ohh, heck - it’s a command switch…? 😅😂
By manual, you mean the readme, right…? I did peruse/scroll through it, but didn’t see anything.
EDIT: Ahhh, wait. The shsucdx.txt file…
OS: Windows 98 SE
CPU: Pentium III Katmai 450MHz (SL35D)/Pentium III Coppermine 933MHz (SL448)
RAM: SK Hynix 128MB 100MHz/Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/Geforce 128MB 4 MX 440
Motherboard: MSI-6156/Abit BE6-II
Reply 22 of 33, by Geri
config.sys:
DEVICEHIGH=uide.sys /N1 /N3 /R15 /D:CD000
autoexec.bat:
lh shcdx86 /D:CD000 /L:D /Q
TitaniumGL the OpenGL to D3D wrapper:
http://users.atw.hu/titaniumgl/index.html
Reply 23 of 33, by jmarsh
Geri wrote on 2025-02-13, 11:08:
config.sys: DEVICEHIGH=uide.sys /N1 /N3 /R15 /D:CD000 […]
config.sys:
autoexec.bat:
Did you read anything inside the thread, or just the title?
Reply 25 of 33, by DustyShinigami
Progress! Okay, I removed shsucdx from the autoexec file, so it’s just shsucdhd. In the batch file it’s…
LH C:\SHSUCD\SHSUCDHD /F:D:\ISO\SIMONDOS\CD.ISO
LH C:\SHSUCD\SHSUCDX /D:SHSU-CDH
D:\DOSGAMES\SIMON\SIMON.BAT
The game loads up! 😄 However, for some reason there’s no music. But there are voices. And I presume SFX. So I’m not sure why music isn’t present. It could be UNISOUND being an arse again, but everything is set up and initialised on booting DOS.
OS: Windows 98 SE
Reply 26 of 33, by LSS10999
DustyShinigami wrote on 2025-02-13, 21:41:
Progress! Okay, I removed shsucdx from the autoexec file, so it’s just shsucdhd. In the batch file it’s… […]
Does the game use Redbook CD audio for music? Some games of that era do and they are usually saved in BIN/CUE format (or even ISO/WAV/CUE), with the CUE describing the data as well as audio tracks. ISO is only the data portion so you won't get any music.
On the other hand I don't think SHSUCDHD can handle CD audio. Not sure about SHSUCDX but on my current DOS systems I wasn't able to get any CD audio working despite having properly connected the 4-pin CD cable between the CD drive and sound card...
Reply 27 of 33, by DustyShinigami
LSS10999 wrote on 2025-02-14, 00:37:
I don’t believe so, no. It’s just a regular ISO and it works correctly under Windows. Plus, it uses MIDI music. Any red book audio CDs I have, I’ve already converted to BIN/CUE, which I know this utility can’t load/read.
Also, I take it I can also use SHSUCD to play physical CDs as well, if it’s using MSCD001? I tried assigning a drive letter to it at the end of the command (E:), but that meant SHSUCDHD was no longer installed/initialised.
OS: Windows 98 SE
Reply 28 of 33, by DustyShinigami
Ahhh, no. Turns out I’d connected my sound canvas up incorrectly. 😅 But there’s no music for the DOS version of Simon 1 via it anyway. I’ve remembered - there’s no (official) support for the SC-55 with it. Only MT-32.
I’ll try everything again, but with Simon 2. Though I have noticed a hanging note bug even with that.
OS: Windows 98 SE
Reply 29 of 33, by DustyShinigami
I'm presuming it isn't necessary, but do you need to unload/unmount and image before loading another? I can get Simon 1 working, but other CD images seem to refuse to load, such as Simon 2 and DOTT. 😒
OS: Windows 98 SE
Reply 30 of 33, by DustyShinigami
I still need some guidance with a few things. Specifically the questions I asked. I can only seem to load one game and if I try loading another, it doesn’t and says SHSUCDX or MSCDEX is already installed. I figured I’d need to unmount the previous image first, but adding that command to the end of a game’s batch file doesn’t look to be doing anything. 😕
OS: Windows 98 SE
Reply 31 of 33, by DustyShinigami
Quick question: can SHSUCD be used to load physical CDs as well? Or is it purely images?
Also, how does one go about setting it up if you need to switch discs mid-game?
OS: Windows 98 SE
Reply 32 of 33, by 8bitKittyKat
DustyShinigami wrote on 2025-02-14, 02:09:
You have to unload both SHSUCDHD and SHSUCDX before loading another image.
If you're using a batch file to run your game you could put the commands for unloading in the batch file after your game exits.
DustyShinigami wrote on 2025-03-02, 01:39:
I haven't used it for physical CDs myself but as I understand it SHSUCDX works as a replacement for MSCDEX, so I believe so?
I don't think you can switch disk images mid-game unfortunately.
Reply 33 of 33, by DustyShinigami
8bitKittyKat wrote on 2025-03-28, 04:08:
You have to unload both SHSUCDHD and SHSUCDX before loading another image. If you're using a batch file to run your game you cou […]
Thanks for the reply. 😀
In the end, I tried reaching out to the creator of the utility and asked him all the questions I had. He laid out all the commands needed, including how to set it up so it reads physical CDs.
In autoexec: […]
In autoexec:
SHSUCDX /D:MSCD001 /D1
That adds your physical drive and reserves one for SHSUCDHD.
Then for the game:
SHSUCDHD /F:game1.iso /F:game2.iso
SHSUCDX /D:SHSU-CDH,E
F will be assigned automatically.
When done:
SHSUCDX /D1
SHSUCDHD /U
to remove it again, ready for the next game. At least, I think that's right; I stopped using DOS around this time, so never had a need myself.
He also explained about the OMI tool that comes bundled with it for making the ISOs in DOS. Some weren't converting correctly with Alcohol 120% and weren't mounting/loading correctly.
OS: Windows 98 SE
