Reply 56440 of 60056, by H3nrik V!
- l33t
GigAHerZ wrote on 2025-03-28, 11:05:I have an identical 9250. It has 128-bit bus and 166MHz VRAM. If yours, for whatever reason, has a bios with 200MHz VRAM setting […]
H3nrik V! wrote on 2025-03-28, 09:16:Bought a couple of AGP cards. […]
Recently bought a Radeon 9600 passively cooled for my P2B-DS, not thinking about AGP x8 coding 🤣
So in stead, I now found a 9250 which has the right coding, and should be BX compatible according to other posts here.
The really cool thing is, it has 8 memory chips, so it could be a 128-bit memory version (at least, that's what Phil found here: https://www.youtube.com/watch?v=TDdA0d8f6uQ and it is the excact same version as far as I can tell)
Auction started at 0.99€, no reserve. Got a snipe for 4€50 - happy 😁
The reason I wanted a Radeon over a GeForce is that it according to this forum, GeForce drivers really fogs up PowerVR drivers, and I do have a Matrox m3D in the same rig ..Same seller did, however, have a passively cooled FX5200, which also had 8 memory chips, so betting on it being a 128-bit (or crossing fingers at least)
Same starting price, no reserve. No other bidders, so got it for 0.99€ 😎I do have an FX5200 in the build now, but a 64-bit. If I decide to move the PowerVR elsewhere, it might be pretty cool with a 128-bit FX5200 (Yes, I know there are way faster alternatives, but the key-word here being "passive")
Combined shipping, all in all a real good catch. On their way with UPS now.
All untested, so off course, some risk 🤣
If yours, for whatever reason, has a bios with 200MHz VRAM setting, can you maybe dump it? My card runs easily at 200MHz, but i would very much prefer bios level OC over any program running in windows.
If yours has any problems over DVI (full-screen command prompt while running windows for example), then i can share my bios with you which may fix the issue - this card in my possession does not have this issue. (I have some other 9250s that do exhibit issues over DVI)
Cool, I'll try to remember that 🤣
If you DM me, I can leave that unread, until I have tested it out 😉
