Reply 2160 of 2663, by DonutDroid
Thank you so much, my friend!
Reply 2161 of 2663, by Abu Brandino
Falcosoft wrote on 2025-03-15, 19:04:
Hi, I have added a new command line option (/vstdelay ms) to new test version: https://falcosoft.hu/midiplayer_65_test.zip After […]
Abu Brandino wrote on 2025-03-14, 23:41:
Hi mate, I just wanted to put forth an issue from Roland's end that maybe you could be able to mitigate on your program. The SCVA needs to authenticate every time it runs on a computer and if you have the MidiPlayer to run at startup with the VST autoloading the VST doesn't see the authentication ticket until the computer has been on for a bit. Since MidiPlayer starts up pretty quickly it always thinks it's unauthorised unless you stop the VST and restart it. Do you have an idea on how to mitigate it, it becomes a hassle to keep rebooting the VST on startup which kind of negates the whole idea of having the Player start on Log-in. Thanks mate.
After starting the new exe you should try to disable and re-enable the 'Main menu -> Start with Windows (System Tray)' option.
This will add a new parameter (/vstdelay 1000) as startup option to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\MidiPlayer.
This change will result in a 1 sec. (1000 msec.) delay of loading VSTi plugins which most likely will not be enough on your system. But you can try to increase the delay value step by step until you find a sweet spot (use Regedit to find and edit the value).
Still getting an RCM service not found on startup.
Reply 2162 of 2663, by Falcosoft
Abu Brandino wrote on 2025-03-29, 04:01:
What delay values have you tried? Have you tried e.g. 5000 ?
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2163 of 2663, by RetroGC
Hi.
It's passed a while since my last request.
I was trying to listen to some mod files through your software. Conversion works great with few track/instruments mod but I'm having some issue with complex mod files with 21 tracks (and 30 instruments). Could it be possible to arrive to channel 32 with midi created (and maybe to avoiding percussion channel as some editor has issue with this)? I was trying to record Deus EX Ost.
Thank you for your help.
My Videogames Music Channel
My Videogames Music Channel Thread
Reply 2164 of 2663, by Falcosoft
RetroGC wrote on 2025-03-29, 09:33:
Hi. It's passed a while since my last request. I was trying to listen to some mod files through your software. Conversion works […]
Hi.
OK, here is a new version that supports 16+ channel modules by converting them to multi-port (16+ channel) Midi files. The converted Midi files work automatically in Midi player but in other software most likely you will have to manually adjust the tracks where ports are set bigger than 0.
As for using Midi drum channels during module conversion: There has been an option to disable this behavior for a while. If you run mod2midi.exe without any parameters you can get the options:
Usage: mod2midi <source_file> <destination path> <use drum channel[0/1]> <by inst[0/1]> <by track[0/1]>
Using drum channel stays enabled as default since Midi player has no problem with this setting and this way you will need one less port for 16 (and 32, 48 etc.) channel module files.
The attachment mod2midi.zip is no longer available
BTW, mod2midi active development has been stopped for a long time. My motivation for fixing more bugs and problems has been reduced even more since Ian at un4seen has released his 2MIDI software for free and it is much more polished than mod2midi.
So if you experience further problems with mod2midi then you should use 2MIDI instead:
https://www.un4seen.com/2midi.html
Website, Youtube
Reply 2165 of 2663, by DracoNihil
I'm not sure why but on Wine 10.4 the program doesn't have any window decorations and as a result I can't snap the window anywhere on my desktop environment. I don't think this is intentional is it?
Atleast; I don't see a option anywhere in the drop down menus that would cause it to not permit window decorations. Seems like a Wine regression maybe?
― Κυνικός Δράκων
Reply 2166 of 2663, by Falcosoft
DracoNihil wrote on 2025-03-30, 20:14:
All I can say is that nothing related has changes in Midi player. So if it worked with previous Wine versions then it is definitely a Wine regression.
Website, Youtube
Reply 2167 of 2663, by Abu Brandino
Falcosoft wrote on 2025-03-29, 07:09:
What delay values have you tried? Have you tried e.g. 5000 ? Remember what I wrote: […]
5000, 10000, 300000
Reply 2168 of 2663, by Falcosoft
Abu Brandino wrote on 2025-03-30, 23:24:
5000, 10000, 300000
300000 means 5 minutes so if you look at Midi player by opening it from the system tray after a system restart you should see that the plugin is not being loaded at all for 5 minutes. Is this what you see?
Website, Youtube
Reply 2169 of 2663, by RetroGC
Falcosoft wrote on 2025-03-29, 15:27:
Well, I think I can not agree. I've found a complicated user interface, instead of an easy command line.
Still have to figure out if this other software works on a complete file or just on channel, and inside user interface I could'nt select above 16 channel...
Your is a great piece of software.
Reply 2170 of 2663, by Abu Brandino
Falcosoft wrote on 2025-03-31, 00:26:
5000, 10000, 300000
No, the VST launches straight away.
Reply 2171 of 2663, by Falcosoft
Abu Brandino wrote on 2025-04-03, 09:32:
5000, 10000, 300000
Then your Midiplayer.exe is not the right version or you must have done something wrong. So:
1. Check that you really downloaded and using the right version. The file version should be 6.5.0.8.
2. Then check if the vstdelay parameter works for you locally with the help of the attached midiplayer.bat file. Its content is midiplayer.exe /vstdelay 10000 so it simply sets a 10 sec. delay. The bat file should be copied to and then should be started from the same folder as midiplayer.exe.
The attachment Midiplayer.bat.zip is no longer available
Test video:
https://youtu.be/9IrhOpL6kYM
3. If it works the same way as shown in the test video then you should check if you modified the vstdelay parameter properly in the registry.
Website, Youtube
Reply 2172 of 2663, by Abu Brandino
Falcosoft wrote on 2025-04-03, 10:37:
Then your Midiplayer.exe is not the right version or you must have done something wrong. So: […]
Test video:
So I just turned it off, restarted, then turned it on and the regedit value works now just like the .BAT did.
Unfortunately that doesn't fix the issue. It's definitely on Roland's end because always on first launch of the VST now it has a stupid error about RCM service not being connected or running or something, then once you get past those boxes it runs as usual. The delay helps the authentication issues I think but in terms of preventing the boxes at startup, I don't think there's anything you can do...unless you know what's causing it.
Reply 2173 of 2663, by Falcosoft
Abu Brandino wrote on 2025-04-04, 12:48:
Test video:
I'm sorry it could not help. Unfortunately I have no idea what can cause the problem on Roland's side.
Website, Youtube
Reply 2174 of 2663, by Abu Brandino
Falcosoft wrote on 2025-04-04, 15:16:
Test video:
Don't stress man, you're doing an awesome job. Roland just being typical Roland making it hell for their own users. They discontinued the SCVA and yet their "offline" installer still requires the RCM Service and constant checking the authentication servers that you're still logged in.
Reply 2175 of 2663, by Falcosoft
FSMP version 6.5 has been released:
https://falcosoft.hu/softwares.html#midiplayer
Test version is no longer available.
version 6.5
1. Added offline recording mode (right click context menu of the red 'Record' button). If it's enabled you can render wav/mp3 audio at full speed in Bassmidi/VSTi output modes.
2. Extended RMI + SF2 support according to new specification (https://github.com/spessasus/sf2-rmidi-specification).
3. Added ability to identify and restore Midi In/Out ports by name instead of position.
4. Added MT32->GM/GM->MT32 patch conversion option to Event Viewer/Debugger (Actions menu -> Convert Patches).
5. Added Redirect GS/XG drums to channel 10 compatibility option. This is a TMIDI bug emulation that can be useful for synths that can only use channel 10 as drum channel.
6. Added SSE support detection for x86 and added dynamic loading of last Bassmidi version without SSE requirement when it is needed.
7. Added using BASS_MIDI_NODRUMPARAM flag when 'NoSysEx' reset option is selected. This allows Chorus effect on Drum channels in Bassmidi output mode.
8. Added support for special mobile Midi files with non-standard SEM1 section.
9. Added displaying SB HW Limits used/not used for selected soundfont information to Soundfont info dialogs.
10. Added new features and fixes to Mod2Midi converter:
added support for IT files with compressed samples; Unreal engine umx container support; 16+ channel support; backward jump support by Midi loop points.
11. Added new Bass_VST version that removes 32 input/output channel limit.
12. Other minor fixes and enhancements.
Website, Youtube
Reply 2176 of 2663, by appiah4
I am particularly thankful for Change #1, thank you!
Reply 2177 of 2663, by Abu Brandino
Falcosoft wrote on 2025-05-02, 14:23:
Hi, FSMP version 6.5 has been released: https://falcosoft.hu/softwares.html#midiplayer Test version is no longer available. […]
version 6.5
Does your MIDI player have a MIDI converter that can use a VST and/or soundfont to create WAV files?
Reply 2178 of 2663, by Falcosoft
Abu Brandino wrote on 2025-05-16, 02:25:
Yes, there has been a real-time converter for a long time. But this new feature is about the new offline/full speed converter:
Website, Youtube
Reply 2179 of 2663, by datajake1999
Not sure if this is an appropriate topic, but I would like to share a VST version of Timidity that I am working on. This is useful for people who want to play MIDI files with GUS patches. The project source can be found at the following URL: https://github.com/datajake1999/Timidity_VSTI
A compiled version can be found here: https://datajake.braillescreen.net/utilities/ … midity_VSTi.zip
