Win 95 motherboard
Reply 20 of 37, by fosterwj03
I like to tinker. I've been abusing a H310 motherboard for the last couple of weeks. I put an i7-9700k in it today, and I watched the VRMs hit 114 degrees C after only a couple minutes of stress testing in Windows 7.
It should run Windows 2000 on all 8 cores at a reasonable clock rate within the VRM tolerance, though.
Reply 21 of 37, by Hans Tork
fosterwj03 wrote on 2025-03-30, 02:08:
Oh 114 C sounds scary.
Anyway what version of Win 95 are you using? From what I have read it seems OSR 2.1 and 2.5 are best. I think I read a post by Leonardo who advocated for 2.1 though reddit says you can get 2.5 but skip IE installation.
Intel i7-3770/Asus P8H77-M/Gt 980ti - XP
Intel P4(Prescott)/Gigabyte GA-8I915PL-G/FX5200/CT4740 - Win98
Reply 22 of 37, by fosterwj03
I use both the Retail release with Service Pack 1 and OSR 2.5, each on its own 32GB SSD. The biggest draw of OSR 2.x is FAT32 for larger partitions, but AGP support is a plus too (not on my retro rocket, though). The Windows 95 implementation of USB is nearly useless unless you have peripheral drivers that works with Windows 95.
I liked IE back in the day, and I use IE4's integrated shell upgraded to IE5 on my builds. I guess I'm weird like that.
Reply 23 of 37, by jakethompson1
Hans Tork wrote on 2025-03-30, 02:33:
There was the original version, which is the only retail version MS ever sold (all the way up to Win98 release).
If you installed SP1 on that, it became Windows 95a. Among other things, it does not support FAT32 nor USB, and will crash on certain AMD K6 processors that do "nothing" too fast (a timing loop). The patch was only provided for 95B and 9C.
The others are "OEM Service Releases" aka OSR.
I don't remember the exact differences between OSR2 or OSR2.1 but there was a version "B" of such.
OSR2.5 is version "C".
Win95 "C" will install with IE 3.02, then attempt to install 4.0 on first boot. You can Ctrl-Alt-Del to stop the IE4 installation.
There is also a process you can follow, where you edit the .INF files before installation, to bypass installing crapware including AOL, CompuServe, etc. You can read about it on the ToasyTech site. Things have come full circle, it's a lot like using an Autounattend.xml file with Windows 11 to install without a Microsoft account.
You can install the "USB Supplement" on 95C if you want, but I never do. If you want USB, use 98. The USB supplement includes an extremely early version of WDM support.
Reply 24 of 37, by fosterwj03
jakethompson1 wrote on 2025-03-30, 03:13:
There was the original version, which is the only retail version MS ever sold (all the way up to Win98 release). If you installe […]
The timing loop bug fix works on the retail release as well. The bug is in the basic disk driver and NDIS driver that shipped in all releases of Win95.
Reply 25 of 37, by STX
fosterwj03 wrote on 2025-03-30, 01:23:
Hans Tork wrote on 2025-03-30, 00:19:
...Personally I have never used a Win 95 system(any version), so I do not know much about it`s stability.
Rock solid, as a matter of fact....
Assuming that the hardware isn't failing, there are no IRQ conflicts and good drivers are properly installed, Windows 95 is rock solid...until installed programs mess it up. Windows 95 doesn't protect itself from installers that create DLL hell, add too many fonts or do all kinds of mischief in the registry and *.ini files.
Since you will be using an MMX processor, any of the OSR 2.x versions would be suitable. You'll want bug-free MMX support for some games from 1997.
MSIE version is just a matter of personal preference, and so is installing or not installing Desktop Update. My parents used MSIE 5.5 on Windows 95C without Desktop Update until 2004, and they were comfortable with it. I had installed Desktop Update with MSIE 4 (a very long download) when it first came out, but then I reinstalled Windows and updated MSIE without Desktop Update because I hated how Desktop Update slowed down Windows Explorer. (The system had a Pentium and 48 MB of RAM.)
Reply 26 of 37, by fosterwj03
STX wrote on 2025-03-30, 03:25:
All true. I usually have a minimal install and only programs I like to use and trust after all these years.
Reply 27 of 37, by fosterwj03
Oh, I also install the Plus! pack for Windows 95. I really like the visual enhancements.
Reply 28 of 37, by Hans Tork
Assuming that the hardware isn't failing, there are no IRQ conflicts and good drivers are properly installed, Windows 95 is rock […]
Once again thanks for the insight. Win 95 seems a lot like Win 98se then. There too the OS gets messed up if one puts a lot of extraneous software. Sometimes Win 98se goes to a BSOD with a new hardware or a new USB.
Reply 29 of 37, by Hans Tork
fosterwj03 wrote on 2025-03-30, 03:37:
I have the Plus pack for XP and I think it adds some "dancers" and also a few other things. Not too impressive but something I did not have in my original OS.
Reply 30 of 37, by Hans Tork
So OSR 2.5 without IE4 is the way to go or should I get the OSR2.1 version. Also I do not plan on using USB of any kind. My KB+mouse combo is PS/2. For file transfer I will be using another PC. I think I might not have mentioned the storage but I got a PATA SSD(used in laptops) with a converter to normal PATA. I have an adapter to connect it to a modern PC.
Reply 31 of 37, by Jo22
Not sure if I should mention this, but I remember from back in the 90s that development of Windows 95 was rushed.
The Windows 95 RTM release was in a state of being "good enough" but by no means finished.
It was a beta product, in all honesty. Critical computer magazines and journalists in 1995 had talked about this.
In retrospect, Windows 95 was a big hype also. So I suppose it's not possible to rationally discuss this.
Edit: The Netscape (?) guys described Windows 95 as "a pile of bad drivers" hinting on the VXD contruct that Windows 95 is/was.
Edit: Correction, it was described as "a mundane set of poorly debugged device drivers" by a Netscape guy.
Reply 32 of 37, by leonardo
Hans Tork wrote on 2025-03-30, 04:05:
I'll just clarify why I've stuck to recommending OSR 2/2.1 (B) and not 2.5 (C).
In my testing, I found that version C would sometimes completely hang when installing network drivers, for example - forcing a reboot. This was on the same hardware that had no issues with older versions of Windows 95, and I never could figure out what the root cause for it was. That combined with the fact that you have more work to do if you want a clean install (without IE) - and that realistically there are no added benefits that I could find (all the same updates apply, drivers work, etc.) - and it's an easy recommendation.
I think version C was only done to promote the idea of "IE is now a part of Windows" - as a sort of stopgap between what people knew as Windows 95 and the upcoming Windows 98.
As for the USB-supplements, you should install them on Windows 95 OSR2 regardless of if you intend to use USB-devices, because Microsoft has this way of building interdependency with other updates. For example, I believe AGP support was also tied to having the USB-supplement installed somehow. OSR2 = version B, no USB supplement, OSR 2.1 = B, with USB supplement.
All that said, XUSBSUPP is USBSUPP and USBUPD2 in one package, + tray utility for ejecting USB media + generic storage drivers, so I do recommend that over the original updates bundled on the installation CDs.
It's all in my guide, and the latest system I have in use with Win95 is my Athlon 1.2 GHz with a ViA chipset and an AGP Radeon 9700 Pro. It's a good setup, close to yours, but took some tinkering to figure out how to properly set it up. As you've noted - Windows 9x are kind of flakey if you do the wrong things (or things in the wrong order).
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 33 of 37, by Hans Tork
leonardo wrote on 2025-03-30, 11:29:
I'll just clarify why I've stuck to recommending OSR 2/2.1 (B) and not 2.5 (C). […]
Thanks for the tips. I have been reading your guide for the Win 95 OSR2.1 installation and I find it very enlightening. I had so much trouble with the Win 98se installations before stumbling onto a stable setup.
Reply 34 of 37, by chinny22
I've run Win95c without problems ever since it was the current version. If installing off the HDD just delete the IE4 cab files and it'll skip the install.
If installing off the CD (Not recommended) remove the CD while it does it's final reboot during setup. It'll ask for the CD but just hit cancel and it'll never ask again you have a clean install without IE.
Also re multiple video cards. Win98 does support this as well as multiple screens
Don't think Win95 can do multiple screens, but if you could probably do 2 video cards e.g. AGP and PCI and set the one you want to use as primary in BIOS and it'll ignore the other.
Say if you wanted to use 1 card for a certain game.
Reply 35 of 37, by leonardo
chinny22 wrote on 2025-03-30, 23:16:
This is not exactly correct, you'll be left with the stock install of Microsoft Network, Mail, IE 2.x or IE 3.x - so still a bunch of unnecessary garbage. You will, however, avoid installing IE 4 and the Active Desktop update, so what you propose is in that sense at least a little cleaner. The same method for cleaning up IE (all versions of it) by modifying the installation files works for both B and C-versions of Windows, and is really easy to do. It only involves editing a couple of text files.
Reply 36 of 37, by chinny22
leonardo wrote on 2025-03-31, 15:41:
I guess I should have said "clean install without IE4"
What I was trying to say is by removing the IE4 cabs or CD you get the latest version of Win95 installed, including USB support? but without the resource hogging IE4 and Active Desktop.
but yes it'll still install other possibly unwanted crap
Reply 37 of 37, by leonardo
chinny22 wrote on 2025-04-01, 03:22:
I guess I should have said "clean install without IE4" What I was trying to say is by removing the IE4 cabs or CD you get the la […]
Oddly, I think version C also requires the installation of USBSUPP or XUSBSUPP for USB-support (...and AGP support?). It muddles the difference between the B- and C-revisions of OSR2.x. I'm not what the differences between the B- and C-revision without IE 4 and the USB support patch really amount to. If I really wanted to dig, I'd examine all the dll-versions etc., I suppose.
