Turkish translation
First post, by wakeup
Is it possible to translate DosBox into Turkish? If yes, how can i help with the translation?
Thanks...
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Yes, DOSBox will work with extra language files. You can find some here:
http://www.dosbox.com/download.php?main=1
Also see section 12 of the DOSBox Read-Me file:
http://dosbox.cvs.sourceforge.net/dosbox/dosb … DME?view=markup
_________________
Reply 2 of 5, by wakeup
I read the readme file but couldnt findthe config.com file to create language file... Where can i find?
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
The CONFIG.COM program is inside DOSBox, on the Z-drive.
Start DOSBox, and type
CONFIG -writelang MyLanguageFile
That will create the file "MyLanguageFile" somewhere on your computer. After that you can edit it with your favorite text-editor (well, almost - it might not work with all editors).
_________________
Reply 4 of 5, by wakeup
Yes I've started translating but it doesnt support Turkish characters? can it be corrected?
Reply 5 of 5, by MiniMax
Rank Moderator
Moderator
Not sure what you mean. When I look at the download page for the different language files, I see translations into Russian and Korean. If it works for those languages, I am sure it will work for Turkish too.
_________________
