I'd say don't lock yourself to RDRAM and instead consider the i845 chipset with DDR RAM if you're dead-set on having a P4 board... or even better - an i865 chipset board.
If you live relatively close to Eastern Europe, looks for some of the local classifieds sites there (e.g. OLX) and see if you can get shipped something from there.
Where I am, I can often get working P4 systems for $20 with all kinds of interesting hardware.
And locally (flea market), it's even better - last weekend, for example, I got a whole PC for just under $4, containing a Gigabyte GA-8iPE1000-G motherboard (P4 i865 chipset) with a 2.6 GHz P4 HT, 512 MB of RAM, Gigabyte FX5200 64-bit video, and even included a 40 or 80 GB HDD... all in a pretty cheapo garbage case with cheapo garbage PSU. But for $4, I can't complain at all. This is my 3rd GA-8iPE1000--- board so far. The 1st one was out of a pretty gutted and beaten case for $5, but the bonus part was that it came with a GeForce 4 TI4200... which I still need to clean up and test (not high hopes it will work though, due to someone fudging with the cooler on top quite a bit.)
Anyways, lots of P4 systems to be had around this part of Europe, so definitely check it out. Ebay will probably have similar, but it's going to be more expensive likely. I haven't been on Ebay ever since I moved to EU - just more expensive compared to local stuff.
Unknown_K wrote on 2025-04-02, 21:04:
How popular was DELL in Europe during the P4 era? We still have a massive supply of those plastic DELLs here cheap. If you want to build one with a gamer board of the era, then costs go up quite a bit.
Not that much at all.
When I used to live in the USA, indeed the P4 era Dells where just about everywhere, especially back in their hay-day. Even today, you can still find these for $20-40 locally and mostly complete. Just beware that many of the Dell PCs from that era were notorious for not having an AGP slot. And worse, models like the Optiplex GX260 and GX270 were almost always affected by bad caps (and probably the equivalent Dimension models too.)
By the looks of it on eBay though, the prices there are almost 2x what I noted above. I was even going to post links to a few I found (in the US), but after seeing O/P is from Europe, I suppose there's no point now.
That being said, I will post only one that I found kind of interesting, in case anyone else in the US might be looking for one. It appears to be a complete Gateway E3600 system. 1.6 GHz P4 Willamate (likely) and 512 MB of (likely) SDRAM... so not exactly a great P4 system by any means... but at least it comes with an HDD. And the beige case is probably the nicest thing about this system.
https://www.ebay.com/itm/236029016643
(and no, I'm not the seller of this or affiliated in any way... but figured it was a beige system interesting enough to post here.)
