Reply 100 of 260, by red_avatar
- Oldbie
I've been testing the ZuluIDE for a week now and here's my 5 cents:
THE NEGATIVE:
- the device really doesn't like many images on a single SD card. The board itself takes minutes to come "online" in my case and my card has about 350 images.
- the web interface also conks out when you have a lot of images - the list to select from is simply broken and randomly starts halfway the list most of the time. It sometimes takes 4-5 refresh for the list to even appear and it takes several minutes for it to do so so you can waste a LOT of time this way.
- if you power the device using internal PC power, it has to start up each time you shut down the PC. When you have a lot of CD images this means it keeps taking a while before the CD drive becomes accessible.
--- it all boils down to the same one big negative: this device cannot handle a lot of images ergo you need to work with smaller SD cards with less images (100 tops) ergo you need to be able to access the SD card slot if you need more.
THE MEH:
- the web interface definitely needs more work - it works and is functional but it could be so much better. I know it's a work in progress and I'll keep a close eye on development
- no official interface available to operate the device besides the web interface
THE POSITIVE:
- when images are loaded, after testing some 70+ games in DOS 6.22, I found zero issues. CD audio always works, no hiccups in games, nothing. CD drive speed is akin to a 24x drive on the PC I tested (Pentium 120Hz) but I use a very long IDE cable which might impact speeds.
- the OAK driver and VIDECDD drivers both work perfectly
- the micro USB connector allows you to power the device without having to use the internal connector - this way you can keep it powered even when shutting down the PC.
TIPS FOR OTHERS:
- The board is best used externally for now - I used a 60cm IDE cable and slid it between the case and the lid + used a long CD audio cable so I can fully use it outside of my case + power it using micro USB cable.
- Keep each micro SD card to max 100 images to prevent it taking too long for the ZuluIDE to boot & to prevent the web interface from conking out
In the end, I'm glad I bought it but it does need more work & there needs to be an easier way to (a) swap SD cards and (b) swap images on the SD cards. The web interface is functional but flaky and the lack of an official control board hampers the usability for a regular retro user.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
